What can I measure to tell what height my lift is
#1 | |
Can someone tell me what parts I can measure to tell what lift I have on my 97 TJ?
#2 |
what type of lift is it?
#3 |
I beleive its a skyjacker lift. 2-4"s of lift... Not really sure how to tell. I want to order new bushing and need to know before I can.
#4 |
Demonic Jeep Freak!
Measure the gap between the fender flares and tires.That should give you an indication of how much lift.My brother has 33's and 3" of lift.He has 4.5" front and 5.75" rear.
#5 |
measure and post up the length of the front spring while the truck is sitting flat.
I don't have enough lift to "stuff a tire" |
#6 |
post pictures, we may be able to tell
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA |
#7 |
His profile has pics...
JEEPLESS... :( |
#8 |
23.8 inches
![]() 36.8 inches - 8 inches - front tire measurement 15.6 - passenger coil on the ground |
#9 |
about 3.5" of lift.
The stock coils are about 12"
#10 | |
Cut to Fit-Paint to Match
You sure about that? I'm running RE 3.5" SF with 33s and My measurement from the floor to the bottom of the rockers is just under 25-1/4". OP is only measuring 23.8" to the bottom of the tub.
We save dogs: http://www.secondchanceshepherds.org/ |
#11 |
That's less than 4 inches as it currently is, probably agree with 3.5". That's also a small tc drop for 4".
#12 | |
#13 |
measure from the top to the bottom of the spring in the front.
and subtract 12....and u've got ur lift atleast thats what i've heard.
4-4.5 inch susp. lift. 1 in performance acs. body lift. 5 in offroad foglights. Brushgaurd. Atoz corner armors.Round 4in taillights.D35/30 combo. upgraded horn.radio.8inbazzoka tube.highlift jack. 1.5in wheel spacers. 33' goodyear wrangler mt's. |
#14 |
When my LJ was stock it measured 19.5" front ,20.5" rear .
Those measurements are taken from the center of the wheel center cap to the bottom of the fender flare. This eleminates the differance of wheel/ tire sizes.
/l ,[___], l--L --OlllllO- ()_) ()_)-o-)_) -2006 Impact Orange LJ- MY BUILD THREAD http://www.jeepforum.com/forum/f22/nmlj-stock-rock-1077208/ THE HARDEST THING ABOUT A ZOMBIE OUTBREAK WOULD BE PRENTENDING NOT TO BE EXCITED
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
