What is the best 4 in long arm for the money? - Page 2 - JeepForum.com
post #16 of 20 Old 07-16-2010, 04:45 PM Thread Starter
wranglerWestLA
I already did some work on this Jeep and spent $$$
I simply think that it is not worth it to change axles...dana 44 front and rear on my 97 TJ.
and I read and heard than dana 30 and dana 35 don t do good with 35s.
I went offroading last week in gold mountain trail in Big Bear and Jeep did very well.
Now I wanted to lift it a little more and I thought that a long arm would be a good choice.
This is why I asked you guys suggestions/ideas
wranglerWestLA is offline
post #17 of 20 Old 07-16-2010, 05:13 PM
RubiOR
Asking from a position of ignorance... Do most non-triangulated long-arm setups use radius arms or is it common to use short uppers in the factory brackets with long lowers?
'06 Solar Yellow Rubicon Unlimited --
Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy
RubiOR is offline
post #18 of 20 Old 07-16-2010, 05:30 PM
Knuts
You are going to get 1000 different answers from a thousand differnt jeep owners. What works best for one guy may not be best for the next. A year ago I wouldn't have even considered putting a rough country lift under my jeep but last spring my budget for upgrades was lacking and I decided to go with them. I am really pleased with the out come. For $1400 there really isn't another choice out there that I would consider (short or long arm). The best thing to do is try and find someone who wheels about the same as you, has a jeep that is similar to the direction you would go with and then ask their advise of what they like and dislike about their set-up. From friends experiences, there was no way that i was going to settle with a short arm kit for the simple reason that if you decide to put bigger tires under your jeep you will be limited by that kit. I know lots of people who ran 35" tires on their YJs and never had axle issues. It always comes down to controling your right foot.
Knuts is offline
post #19 of 20 Old 07-16-2010, 05:43 PM
UTWeezul
Originally Posted by never monday View Post
I agree, swap out the axles and make it unique instead of another rubiclone
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #20 of 20 Old 07-19-2010, 07:08 AM
Tyler99TJ
I would suggest that you wheel your current set up a few more times before you make any changes. If you have only been on one real trip, you still have a lot to learn about your vehicle. Did you getting stuck because you were running lines that required larger tires? Did you get high centered? Did you bottom out in mud holes? Did you even get stuck on your trip?
The real question is why do you want to upgrade? Where do you need to improve your Jeep. Maybe you had too much tire spin and you need to lock your front axle. Maybe you did not lower your air pressure and were lossing traction on rock. I am guessing you are like me and just want bigger and not sure what your limiting factors are on your current set up.
Tyler99TJ is offline
tj , wrangler , long arm , la , lift , suspension
TJ Rusty's Long arm upgrade long arm kit???? papi32 TJ Wrangler Technical Forum 14 03-20-2012 10:34 AM
Full-Traction Long Arm or Rubicon Express Long Arm GopherGuy TJ Wrangler Technical Forum 14 08-21-2009 06:26 PM
Brake lines-how long is long enough? TJDaveX TJ Wrangler Technical Forum 3 01-13-2008 09:02 AM
clayton long arm vs Rubicon Express long arm Squeeky TJ Wrangler Technical Forum 5 01-09-2008 09:16 PM
tire size with r.e. 4.5 long arm & 4.5 nth degree long arm? David Hinton TJ Wrangler Technical Forum 3 03-16-2007 04:07 PM
