Quantcast What am I missing about "Highline Fenders" - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What am I missing about "Highline Fenders"
Old 12-14-2009, 09:09 PM   #31
Imped
TITS
Imped's Avatar
Originally Posted by 0IIIIIII0 View Post
The relation being, how does one run tires LARGER than mine when I rub already.
You're mistaking flex rub with "improper backspacing" rub. They are two different things and totally unrelated. I'm surprised nobody has said that yet. Your tire are rubbing the sway bar at full lock because you have too much backspacing or your axle isn't centered so you're rubbing on the passenger side. Rubbing due to flex is a totally different story and is unrelated to backspacing. That's the type of clearance highline fenders allow. Learn the differences.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 12-14-2009, 09:13 PM   #32
Emdot
I kinda said this on page 1 when I stated I see no relation to highline fenders and rubbing at lock. Perhaps I should have elaborated.
Shawn
1998 TJ 4.0L 5speed
Emdot is offline   Reply With Quote
Old 12-14-2009, 09:45 PM   #33
NEPAjeep02
NEPAjeep02's Avatar
Did i say it also? You can't just go highline and think all of your rubbing problems will disappear. Backspacing is crucial in moving your tires out further from the sway bar links.
2002 Jeep TJ X - See sig
1974 Dodge Powerwagon W200 (Beater)- D44 front(4.10), D60 rear(4.10), 318 V8, NP435, NP205 NP203 Doubler. STOLEN
1980 CJ-5 - Parting out. Let me know if you need anything.
1983 VW Rabbit GTI - 2.0 ABA swap, etc.
1998 VW Jetta GT - Parts car
NEPAjeep02 is offline   Reply With Quote
Glock Forum
