#16 | ||
They are making and selling the fenders and hood, not the axles, wheels, tires, suspension or steering components. That is like saying a lift company is misrepresenting their 6.5" lift by claiming it will clear 37" tires. AEV sells and makes a lot of other products, I am sure if you are that interested they can hook you up with a full new suspension to "properly" run whatever tires you want, new rims with backspacing more appropriate, and they can most assuredly steer you in the direction of some companies who will build some nice axles for you. Just don't expect a company to make a disclaimer on a new hood and fenders that says "you should probably rebuild your whole Jeep if you buy this and expect to wheel it hard." That is a bit of a ridiculous expectation IMO.
#17 |
#18 |
Nope but I certainly love their products and metalcloak has been great getting me what i need for my LJ. At my bodyshop we now are a distributor of their products but that is strictly for local business and only because I really am impressed with the quality of their product. The Gen-Right are also awesome but I wanted the ability to remove the flares as I desired. I like the tube fender idea because it fits the type of wheeling i do. I am not a rock crawling guy at the moment and having lots of clearance isn't a top concern. I do plan to do a savvy TT and gain 4in of clearance and most likely a 2.5 in lift at some point for some additional clearance but who knows. I like mentioning the tube fenders because when I did my first jeep I never thought about doing them and lifted the YJ almost 7in, put waggy d44s and 35s and loved it but I wasn't happy with how it handled on the road. This time around I am paying more attention to a LCG for my own type of wheeling.
#19 | |
Did you get extended end links?
Second, did you ever extend your bump stops? With your setup you will bend your fenders while disconnecting your sway bar and go off road. The highline kit resolves the issue of up-travel contact on the fender, so you can retain maximum travel on a minimal lift, with a bigger tire. |
#20 |
#21 |
Just one part of the solution. Highline generally goes with other mods such as tummy tuck, etc. A tummy-tucked high fender with no lift and 35s would have only about 2" less clearance on the skid than a 6" lifted top heavy jeep w/35s.
#22 |
The relation being, how does one run tires LARGER than mine when I rub already.
#23 | ||
Yes, I did extend the bumpstops. No fender destruction for me. Quote:
#24 |
Wrong endlink length
Never adjusted steering stops Inadequate (IMHO) BS wheel I have flat fenders, run 33x12.50, correctly adjusted adjustable swaybar discos, 3.75 BS, and NO lift. I do not have rubbing issues short of touching the underside of the front fenders at full flex, and it's not enough for me to bother fixing, although even a 3/4 spacer would cure it. When I go longarm, I'll add 2 1/2" springs. Then I'll be able to run 35s. At that point, I MIGHT have to adjust steering stops a bit once again, but for now I have MORE steering than stock.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#25 | |
Demonic Jeep Freak!
#26 |
lol
It kind of goes without saying (at least, it always has for me) that if you're going to upgrade everything else on a jeep and lift it and throw huge tires on it, it's retarded to think that there will not be severe consequences related to the drivetrain (be it gearing, engine-related stress, axles, etc). People are quick to note that gearing changes will be needed for XX" tires, but nothing along the lines of XXaxles with XXgears are needed for XXtires.
Or am I wrong? ![]() Sorry for the de-rail. |
#27 |
#28 |
Resident *** Hole
so i didnt need the d60's????
#29 |
Member 134 of the White Jeep Club 31" BFG A/T's, 130w KC Hilites |
#30 | |
want it rite or rite now?
3.5" DIY highlines on 37's ![]()
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
