What am I missing about "Highline Fenders"
#1 | |
I was looking at the AEV Highline kit last night as that look is intriguing to me (granted I couldn't swallow that price and would have to homebrew mine). The Qtec Ad claims that with it, 37" tires can be run with only 3" of lift. Here's what I don't get. Currently, I'm running a 2"BB with 33x12.50 Goodyear MTR's on Soft 8's w/4" Backspacing. Currently I'm rubbing at full cut on the sway bar. How can raising the fender line increase tire clearance by that much? Am I missing something? I really like the idea of running larger tires without massive lift.
#2 |
when you say rubbing at full cut do you mean when the wheels are turned all the way??
i run 35,s and 4 inch lift only and stuff mine all the time and have never hit the sway bar and i think i have the same back spaceing but not positive.. ![]()
JACK OF ALL TRADES,,,MASTER OF NONE fla cracker head born and bred build- http://www.jeepforum.com/forum/f22/punishers-ezgo-build-thread-1065655/ |
#3 |
I'm running 35s with 3.75" BS and don't rub on anything and I've only got 3" of lift and a 1" body lift...
#4 |
Yeah, that's what I mean, when the wheel is turned all the way, I rub on the sway bar.
#5 |
Is your swaybar disconnected? I know when mine is not I rub but when I have it disconnected and tucked out of the way I'm all set.
#6 |
They are very cool but the fenders are a small part of functionally fitting big tires. If you run the axles needed to be durable, I think you'll find axle and steering clearance to be a bigger challenge than tire vs. fender. I run ~4" suspension and 1.25" bl on 39s and fender clearance was never the issue (staying low and still clearing my 60s at stuff was the hardest part).
#7 | ||
#8 | |
and so their only big issues are durability, limited steering range (increase stops, add spacers, and/or get reduced backspacing) and fender clearance. That'll work for trips to the mall and light foot easy wheeling; so for some it's a quicker way to get the look they want. In the hands of someone like Blaine, the highline style fenders can really compliment a quality build. |
#9 |
Demonic Jeep Freak!
You can run 35's and no lift with the Metalcloak arched tube fenders.
MetalCloak TJ/LJ Arched Tube Fenders |
#10 | |
#11 |
yes and you can even upgrade to the currie system with a little modification
#12 | ||
and yes but then begins the question of function. Is your frame too low (entry, breakover, exit)? High fenders are cool but.... ![]() |
#13 |
You might want to look into larger backspacing.
2002 Jeep TJ X - See sig 1974 Dodge Powerwagon W200 (Beater)- D44 front(4.10), D60 rear(4.10), 318 V8, NP435, NP205 NP203 Doubler. STOLEN 1980 CJ-5 - Parting out. Let me know if you need anything. 1983 VW Rabbit GTI - 2.0 ABA swap, etc. 1998 VW Jetta GT - Parts car |
#14 |
x2 Im not seeing the relation to high fenders and sway bar rubbing at lock
Shawn 1998 TJ 4.0L 5speed |
#15 | |
http://www.stu-offroad.com/steering/stop/steerstop-1.htm
www.youtube.com/kgries http://photobucket.com/kgries in the 80's.... we had Ronald Reagan, Bob Hope, and Johnny Cash. Now we have Obama, No Hope, and No Cash.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
