What is this? - JeepForum.com
post #1 of 5 Old 06-30-2017, 04:48 PM Thread Starter
rcsupercat
What is this?
Is this the discharge tube (pic1) for the water that gets in through the vent (pic 2) ? If so how do I clean it out? What did you use? Compressed air? A long piece of wire? Tia.
rcsupercat is offline
post #2 of 5 Old 06-30-2017, 04:59 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Condensate drain for the condenser inside the HVAC box under the glove box. It lets the water that collects when the AC is used drain out of the box.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 5 Old 06-30-2017, 05:19 PM Thread Starter
rcsupercat
Thanx for the quick reply. So I assume nothing should leak out of it unless the AC is being used? By the way... I installed a set of your brake pads on my 2005 LJ last week and I am extremely happy with their performance. I can actually lock up my brakes if I want to! Thanx for the pads and the help identifying that tube.
post #4 of 5 Old 06-30-2017, 09:28 PM
Jeepsr4me
that tube can get clogged though.. I had a rat nest in mine................. I have pics on here somewhere if you search my name it will show whats inside that AC case.. Dont go poking to hard in it as you could bust something in there...
remembered there is a easy way to find a post i did..
http://www.jeepforum.com/forum/f9/if...right-4041985/
Jeepsr4me is offline
post #5 of 5 Old 07-01-2017, 08:43 AM
1longcj
I think I added an extension on to mine to keep the water out of the frame.
1longcj is offline
