What is 3.73:1 Axle Ratio??? - JeepForum.com
post #1 of 4 Old 03-15-2004, 03:13 PM Thread Starter
jaguar18
jaguar18's Avatar
I hear members talking about upgrading to the 3.73:1 Axle Ratio, and was wondering exactly what is the advantage to having this? My new Jeep has it (checked my window sticker after seeing the posts) but was curious if someone can explain what this actually mean or does. Thanks in advance.
Eric
2004 Solar Yellow X
Columbia Edition
4.0L Power Tech I-6
5-Speed OWL AT Tires
YELLOW JEEP CLUB #76
http://www.imagestation.com/album/?id=4287442317&p=4183305463&idx=1
jaguar18 is offline
post #2 of 4 Old 03-15-2004, 03:31 PM
WhatWasIThinkin
WhatWasIThinkin's Avatar
Thats the drive ratio at the axles
Power in vs. Power out
Driveshaft turns 3.73 times vs. 1 revolution at the axle and wheel.
Alot of Jeeps come with 3.07 gears which are a street gear that works okay on tires up to 29" in diameter......like the common Goodyear GSA's found on most Wranglers on the dealer lot.
3.07 gears dont work well if you decide to go to a larger diameter tire.....like say a 33". Changing to larger tires changes the final drive ratio.
3.73 gears have a couple of advantages. Changing to 33" tires is a little more gear friendly......actually numerically 4.10:1 is even better for 33's.
Another advantage to having 3.73 gears is that you allready now have the carrier made for gear swaps of 4.10, 4.56, or 4.88. Whereas the 3.07 carrier is only good up to a 3.55 gear I beleive. The main difference being bolt pattern between the different rings.
03 Rubicon Shale Green 5 speed
*Engine=Stock* *Armor=OYR Rear Corners, SkidRow Engine Skid, OEM Rockers* *Lift=OME 942HD & 933HD Coils, OME N66 & N67 HD Shocks, ACOS front and rear, 1-1/4" JKS BL, JKS front Track Bar* *Tires/Wheels= 12.5x33" Interco TrXus MT's mounted on 15x8 Cragar 397 Steelies* *Bumpers and Carrier=Jeeperman Rock bumpers front and rear* * Other Stuff=1" M.O.R.E Bombproof Torsion Rubber MML, Meridian Gold GPS, CE 8k Winch*
WhatWasIThinkin is offline
post #3 of 4 Old 03-15-2004, 03:41 PM
we3jeepers
just because your window sticker says you have 3.73
it doesnt mean you actually do
you have to check the id tag on the diff cover
a friend of mine has a Wrangler X
his window sticker said 3.07
he bought a D44 with 3.73's
and 3.73 gears for the front
got the front all apart and the gears were the same
checked the id tag and it said 3.73
so they put it back together
'99 TJ 4.0L
1" motormount lift, 5" of lift, 31/10.5 Goodyear Wrangler ATS, 15x8 AR 767, Dana 30 open diff 3.73 gear, Dana 44 open diff 3.73 gear, Bestop sailcloth top, Tomken gas tank skidplate, skidrow oil pan skid plate, Jeeperman trail skids, Tomken winch plate, Ramsey REP 8000, Rockcrusher rear bumper w/receiver, front & rear tow hooks, borla Header & cat back exhaust, Power Aid throttle body spacer, tera flex discos
we3jeepers is offline
post #4 of 4 Old 03-16-2004, 03:10 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Call DC (goto jeep.com for the cust service #). Give them your VIN and FAX # and they'll send you a build sheet which says exactly which parts went into building your Jeep - including the gearing.
For 04, depending on your options, you may or may not have 3.07's - go to jeep.com and configure a vehicle like yours to see if 3.73's are automaticaly selected (i.e. if you got the 30" tire package, D44 [not avail on X] or Automatic).
2010 Sahara
04JeepTJ is offline
Need different axle ratio. Atjoer JK Wrangler Technical Forum 10 08-17-2008 11:00 AM
Axle ratio help mstout JK Wrangler Technical Forum 16 08-20-2007 12:05 PM
Sahara - Axle locker? Axle ratio? Meir10 JK Wrangler Technical Forum 8 02-25-2007 02:15 PM
TF-999 and Axle Ratio dfowler TJ Wrangler Technical Forum 13 12-27-2006 01:35 PM
Axle ratio ? Mike5150 TJ Wrangler Technical Forum 4 02-11-2006 10:01 PM
