What is it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > What is it?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe ULTIMATE "Selectable" Locker System! BroughFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-31-2014, 02:10 PM   #1
BigClay
What is it?
I just bought a 1998 TJ 4.0 with the AX15 trans. The interior carpet is removed and there is a clearish plastic box velcroed to the transmission tunnel right behind the shifter. I am not sure what it is for or whether it needs to stay. It seems fagile and if it needs to stay I want to tuck it up under the dash. So what is it and what does it do? This is a Saharah if it matters.
Current: 98 TJ, 33" TSLs
Past: 94 ZJ, built for the rocks
BigClay is offline   Reply With Quote
Unread 03-31-2014, 02:28 PM   #2
McLovin
I have never come across anything like that before, but then I have never had that exact model either.
Dune rider....
McLovin is online now   Reply With Quote
Unread 03-31-2014, 02:47 PM   #3
Jonny Jeep
Jonny Jeep's Avatar
If it's velcroed it's not OEM. A pic might help.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals (FSMs) and parts lists can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm
If the link doesn't work properly, look for the service manual link under Jeep Resources at the bottom of the page.
Jonny Jeep is offline   Reply With Quote
Unread 03-31-2014, 02:49 PM   #4
UTWeezul
Does the Jeep have an alarm system?
98 TJ
35" MTR Kevlars
TNT Phantom Fenders
PSC full corners and modded 3" flares
4.56s, Aussie front and Detroit rear
Building a HP30...
UTWeezul is offline   Reply With Quote
Unread 03-31-2014, 03:41 PM   #5
goodwrenchdave
Pic would sure help. Sure not OEM.I would guess someone velcroed an alarm motion sensor to the transmission tunnel. (seen a few clearish models). Good central place for such sensor
Could be a hostile and easy to find place for a boomerang (lojack). (and they are not clearish).
goodwrenchdave is offline   Reply With Quote
Unread 04-03-2014, 08:57 AM   #6
BigClay
So here is a picture from the interwebs of what I am talking about. My interior is stripped and rhinolined so I have no idea what the thing infront of the shifter (towards the fire wall) is.
Unread 04-03-2014, 09:25 AM   #7
biffgnar
biffgnar's Avatar
You mean the thing that's pretty much obscured in the picture by the shifter and too far away to read any of what appears to be writing on it?
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 04-03-2014, 09:27 AM   #8
JEK3
JEK3's Avatar
The picture shows what I believe to be a passenger airbag disable switch.
JEK3 is offline   Reply With Quote
Unread 04-03-2014, 09:27 AM   #9
Jonny Jeep
Jonny Jeep's Avatar
That thing in front of the shifter is the passenger airbag on off switch.
Sent from my B15 using JeepForum
Unread 04-03-2014, 11:44 AM   #10
BigClay
Thats the one
Unread 04-03-2014, 11:49 AM   #11
BigClay
Thanks guys, thats what it is! Ok, so that is something that should indeed stay, I will just put the module in the glove box.
Unread 04-03-2014, 11:55 AM   #12
IlliniJeeper
Which wasn't available on '98s as far as I'm aware. My brother's '00 has one, though.
'98 Jeep TJ Sport
IlliniJeeper is offline   Reply With Quote
Unread 04-03-2014, 11:57 AM   #13
Jonny Jeep
Jonny Jeep's Avatar
It's for turning the passenger airbag off if you have little people in the front passenger seat. Whether it's something that should stay is dependent on your need to carry little people up front.
Unread 04-03-2014, 11:57 AM   #14
purplepig
purplepig's Avatar
That's what I thought, but it clearly says airbag disable switch on it. Im not sure why the original poster didn't see that????
purplepig is offline   Reply With Quote
Unread 04-03-2014, 11:58 AM   #15
purplepig
purplepig's Avatar
I just reread the post. That is not a "clearish plastic box"
