Went trail riding, now it clicks when I turn?
#1 | |
I went trail riding tonight and it was completely dry where we went but I had my swaybar disconnected and I noticed that I heard some clicking on my front end and I got out and realized that it clicks once or sort of pops when the steering wheel first moves from front its stationary position. Any idea what this could be? I got underneath and it is coming from the front end where the steering box, upper track bar mount, and pitman arm is but I don't know which one is making the noise. Let me know any thoughts on what it might be. Thanks in advance.
1999 Jeep TJ on 1 tons (OLDER) 2003 Jeep Rubicon (OLD) 2008 Jeep Unlimited X (NEW) |
#2 |
tighten the controll arms, mine did that and that solved it, may need a shop to do it with air tools
[B]91 YJ 4.0/ax15 Stretch to 102" D44s 5.38s Detroits/Hi Steer/38.5"TSLs/Custom full cage/ Corbeau seats/Crow Harnesses/PSC comp corners.[/B] |
#3 |
my swaybar came loose right after the lift install, made a very similar noise, went back and tightened that up and fixed it right up. could be any number of things, but thats my .02.
2000 black tj sport RE 3.5" 35x12.50 bfgoodrich mt's sye/cv conversion warn front and rear bumpers w/ tire carrier shrockworks rock sliders....... KC's BLACK JEEP CLUB MEMBER #36 http://www.imagestation.com/album/?id=2133643326 |
#4 |
Front U-joint? mine has been "ticking" "popping" more and more these days... happens whenever I change load (from accel to decel) or tight turning.
[SIZE=2][COLOR=Navy]MK Motorsport & Fabrication [/COLOR][/SIZE] |
#5 |
I hope it isn't a U-joint.
That will be a little harder fix than just tightening some bolts.
#6 |
I have this problem also. It's been doing it since i put on the 3.5 lift. You just barely have to turn the wheel to make it pop. Anyone have a clue yet?
[FONT=Tahoma][SIZE=1]Word up.[/SIZE] [/FONT] [B]Black Jeep Club V2.0 Member #40[/B] |
#7 |
Do it right or not at all
![]() Join Date: Jan 2003
Trackbar passenger-side mounting bolt loose? Have someone turn the steering wheel back and forth while you inspect the front end to see what is loose or clicking.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#8 |
Went straight to the trackbar and it was a bit loose! all fixed now though! Thanks!
#9 |
Well, I tightened my trackbar and made sure nothing on my sway bar was lose but it still pops when I turn and hit a bump and sort of vibrates a little in 1st gear at low speed under the floor board by my feet? I can't figure it out!!!
#10 |
mine does the click when i turn too, i found out its the tie rod when i turn hitting the discos
#11 |
I will check that......
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
