Well, dead headlights - JeepForum.com
post #1 of 10 Old 08-03-2009, 08:08 PM Thread Starter
Deezul
Deezul's Avatar
I have IPF Harness and IPF Fatboys. Lowbeams were dead tonight. I swapped the relay with the highbean one(same relay) then i get lowbeam but not high. So looks like I got a dead relay. Problem is I cannot locate one anywhere . It is Proquip p1512X ......40A . Closest I can find is the P1512XP which is used for ARB air lockers. Anyone know if these relays are the same or had a similar experience?
2004 Khaki Rubicon. Jeeperman Custom Brushguard and 54" bumper, Kilby steering skid, Skidrow radiator skid, SRC Rockcrawler rocker guards, UFW Al Engine Skid, OME Shocks, JKS Quicker Discos, AEM Dryflo intake;KC Slimlight 130W Long range lights, ORO LiteDots and LitePlate, Banks Stainless Monster cat-back, Eclipse stereo, BA Speakers, Jeeperman Handles, Cobra CB, interior leds... more to come.
**R.I.P NOW TOTALED** 98TJ Sport, 30x9.5 BFG ATKO's on AR Outlaw II's, K&N FIPK, Borla Catback,
Green jeep club member #139
Deezul is offline
post #2 of 10 Old 08-03-2009, 08:09 PM
PILL
If it is just a standard relay you can find one at most any auto parts store.
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline
post #3 of 10 Old 08-03-2009, 08:15 PM Thread Starter
Deezul
Deezul's Avatar
it LOOKS like it but the ipf instructions say these are "dual polarity with spike protection"
Deezul is offline
post #4 of 10 Old 08-04-2009, 01:57 AM
Jonny Jeep
Jonny Jeep's Avatar
There is no P1512XP listed on the proquip site here...
http://www.proquip.com.au/ProductPag...ec/Relays.html
Only reference for XP is on IH8MUD which says it is fitted with spike protection. http://forum.ih8mud.com/100-series-c...witch-arb.html (post 14)
According to the abbreviation descriptions on the proquip site the X means the relays have the same inbuilt protection. Just not sure what the extra P would mean on the ARB relay.
Jonny Jeep is offline
post #5 of 10 Old 08-04-2009, 06:24 AM
Slithering_Joe
You should be able to replace that relay with one available from just about any parts store.
Not sure what they mean by "dual polarity" but I'll guess and say that the 85 & 86 relay pins are interchangeable. Some relays use a diode across the coil for spike protection where polarity is important here. The standard is terminal 86 is (+) positive and 85 is (-) negative. (Always consult with the provided documentation that came with the part.) If the relay uses a resistor for spike protection then the polarity doesn't matter - probably what you already have. Diode protection is better but the resistor is cheaper. Resistor types are more common. Either one is good enough.
How many pins/blades on the relay? 4 or 5?
(single-87, dual-87, 87/87a)
What syle? with bracket, without bracket, skirted?
(ISO mini relays)
Are there any markings on the relay?
(Above: ISO mini relay, 5 blade, dual-87 terminals, diode spike supression across 86, 85)
(If the relay contained a resistor instead of a diode, a simple rectangle will be displayed in place of the diode "arrow" symbol.)
A good online source for relays is here: www.rallylights.com
4.0L TJ
Slithering_Joe is offline
post #6 of 10 Old 08-04-2009, 08:49 AM Thread Starter
Deezul
Deezul's Avatar
5 pins. it p1512x listed here http://www.proquip.com.au/ProductPag...ec/Relays.html. Looks to be a dual 87. No screw hole at top, just a square
Has Diac protection whatever that is.............P1512X12V, 40ADiacA1 FORM A
(2 x #87)
Deezul is offline
post #7 of 10 Old 08-04-2009, 09:05 AM
Slithering_Joe
(2 x #87)
DIAC: DIode for Alternating Current or "two-direction diode" Looks like you found your replacement.
4.0L TJ
post #8 of 10 Old 08-04-2009, 09:51 AM Thread Starter
Deezul
Deezul's Avatar
Thats the problem. I cannot order from there. They don't sell to the public and only in bulk. I need an equivalent..........
Deezul is offline
post #9 of 10 Old 08-04-2009, 10:48 AM
Slithering_Joe
So, this is what your relay looks like?
Four choices here but read my notes:
(A) Go to a "mom n' pop" auto parts store. Auto parts chain store have no talent working there. Ask them for a dual-87 (not 87/87a) terminal "Bosch", ISO mini, or "cube" relay with arc supression. Take note for resistor or diode supression markings on the relay (see post #5 again). Some harness manufacturers interchange the 85/86 terminals. Resistor type relays are common and are not polarized so they will electrically work in just about everything. If the relay has a diode, then you must make sure the polarity is correct for your particular harness. Either type of relay will work as long as the diode orientation is correct for your harness. If you have questions on this ask us.
or,
Check out Susquehanna MotorSports, www.rallylights.com, for the following.
Nice guys in PA who answer the phone. They can help.
(B) RLYB2S6 Mini Relay SPST Dual 87, $8.00
http://www.rallylights.com/detail.aspx?ID=948
(i) call them to see what the difference between items HL87118 & HL87483. They only mention "12V, 40A"
(ii) no supression resistor, no supression diode, no supression diac (supression recommended but it will work)
(C) RLYB2S14 Relay 12V 40A SPST Dual 87 Diode Bracket, $13.22
http://www.rallylights.com/detail.aspx?ID=446
(i) Because of the supression diode, you need to make sure on your circuit that the 86 terminal connection is positive (+) and 85 is (-) negative or to ground
(ii) The bracket does not interfere with anything or you can cut it off
(D) call Susquehanna since I have purchased a no-bracket, resistor type dual-87 relay from them in the past but I don't see it on their site.
Good luck.
4.0L TJ
post #10 of 10 Old 08-04-2009, 12:14 PM Thread Starter
Deezul
Deezul's Avatar
thanks for all the info!
Deezul is offline
Headlights go on, radio goes off. Headlights off, radio back on gary1 YJ Wrangler Technical Forum 10 10-29-2008 09:07 PM
Headlights dead crb577 YJ Wrangler Technical Forum 1 04-29-2007 09:47 AM
The Jeep!!! He Is Dead! D. E. D. Dead! ixl4 TJ Wrangler Technical Forum 8 02-16-2007 03:52 PM
headlights = dead battery bigbubba TJ Wrangler Technical Forum 11 09-21-2006 01:26 PM
Dead Gauges, FAQ Link Is Dead omnipseudo TJ Wrangler Technical Forum 2 05-01-2004 09:05 PM
