Weird Vibration wont go away - JeepForum.com
post #1 of 5 Old 06-20-2011, 08:04 AM Thread Starter
clutchn350z
This is my first post so excuse me if I posted this in the Wrong area. I also dont know too much about the specs of my Jeep yet but will add as i learn more.
I just purchased a 1999 Wrangler Sport 4.0 with a 4 inch lift kit already installed on it. When I first got the Jeep I noticed a vibration in the steering wheel and dashboard that starts right about when I hit 30 miles an hour and continues more vigorously through about 50 miles an hour and then fades away completely above 50 miles an hour.
I have replaced all 4 tires with brand new ones, replaced all the shocks and even replaced the rear axles in hopes that would alleviate the issue. It has lessened the severity of the vibration overall but it is still very noticeable. My mechanic seems to think it may have something to do with the "Pitman Arm" or "Pitman Bar" or possibly the driveshaft.
The vibration only happens when I push the accelerator which leads me to believe its more than what my mechanic thinks but what do I know.
Anyone out there have any ideas or have had a similar issue?
clutchn350z is offline
post #2 of 5 Old 06-20-2011, 08:46 AM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
Sounds like a driveline vibe from the 4" lift.You SHOULD NOT have a drop pitman arm either,unless you have a frame side track bar drop also.How much t case drop does the lift have? A MML would fix it if that's the problem(driveline vibes).
TheBoogieman is offline
post #3 of 5 Old 06-20-2011, 10:24 AM Thread Starter
clutchn350z
Thanks Boogieman! I am not too familiar with Jeep lingo yet as this is my first Jeep and I have had it for 3 weeks. Can you let me know what an MML is?
post #4 of 5 Old 06-20-2011, 10:36 AM
mdm
Farm Wheeler
http://www.jeepforum.com/forum/f27/acronym-list-337953/
MML = Motor Mount Lift. There are two types of MML. One is taller motor mounts that completely replaces the stock mounts. The other is a budget MML which is a spacer that goes under the stock mount. The MML raises the front of the engine/transmission/transfer case assembly which reduced the angle at the drive shaft. This is a common fix for drive shaft vibration caused by suspension lifts. Another common fix is a transfer case drop which is spacers put between the frame and the skid.
At four inches of lift you have entered the range where the best fixe is a SYE, slip yoke eliminator. The SYE puts a shorter, stronger rear output shaft on the transfer case and uses a CV drive shaft.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 5 Old 06-20-2011, 02:58 PM Thread Starter
clutchn350z
you guys are awesome thank you very much
help needed , vibration on acceleration
Weird vibration mikeys91 YJ Wrangler Technical Forum 8 09-21-2010 04:18 PM
Weird vibration offroadjoker TJ Wrangler Technical Forum 4 09-20-2010 06:59 PM
weird vibration mojo747 YJ Wrangler Technical Forum 5 04-04-2008 11:24 AM
weird vibration 93YJfalcon YJ Wrangler Technical Forum 3 06-25-2007 05:26 PM
weird vibration halfline YJ Wrangler Technical Forum 8 07-30-2002 08:28 AM
