Quantcast weird squeal when its cold ?????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > weird squeal when its cold ??????
Old 11-18-2008, 08:26 PM   #1
abeshures
i have a 2004 rubicon with a 2.5 lift and a 1.25 bodylift. I have a weird squeal between 30 and 40 and it does it every so often but gets worse when its cold. The noise stays constant and does not get louder or quieter. it goes away around 45. I have no idea what it could be. Please help
abeshures is offline   Reply With Quote
Old 11-18-2008, 08:35 PM   #2
autotechboy111
does the squeal happen to go away when you push and hold in your clutch? If it does it could be the throwout bearing.
autotechboy111 is offline   Reply With Quote
Old 11-18-2008, 08:43 PM   #3
MikeBK
MikeBK's Avatar
Check out the thread I started a little further down the page
http://www.jeepforum.com/forum/f9/front-end-squeek-only-when-cold-634008/
MikeBK is offline   Reply With Quote
Old 11-18-2008, 08:49 PM   #4
abeshures
thanks that sucks lol i was hoping it wasnt ANGRY SPARROWS any other suggestions or thats pretty much more than likely what it is?
Old 11-18-2008, 09:43 PM   #5
MikeBK
MikeBK's Avatar
Like I said in my thread, it sounded like it was a wheel bearing, but I have been wanting to rebuild the front driveshaft with some stronger as well as greaseable u-joints anyway, so I will start there.
Old 11-19-2008, 12:06 PM   #6
sporticon03
Mine makes a similar noise in the winter...could be a belt
sporticon03 is offline   Reply With Quote
Old 11-19-2008, 09:09 PM   #7
abeshures
yeah i changed the belt. im gunna replace the u-joints and go from there. its got 42000 miles and i think its time for new ones
Old 11-19-2008, 09:16 PM   #8
CaleTJ99
My jeep makes a squeak when i turn the wheel when i start up for the first time. I sparyd the sterring collum with some wD40, it stopped it for a wile ut its back now. Could it be the u-joint on the steering shaft?
Originally Posted by Solidkm View Post
and never monday we all know you invented 4 wheel drive, and you cold forged the S35 in the depths of moridor, but this is 44 vs 88. so when the next 35 thread comes up. you can play for that team:kiss:
CaleTJ99 is offline   Reply With Quote
Old 11-20-2008, 07:12 PM   #9
MUDMNKY
Good idea, Mike!
I posted this also at the thread you started, Mike. Found a dry, rusted bearing cap when replacing a u-joint in the cv assembly today. Yeeee-haw, my "angry sparrow" has flown! After reading some of those other posts, I decided not to wait a day longer. Have fun! (I mean that in a good way, )
MUDMNKY is offline   Reply With Quote
Glock Forum
