Weird Sound - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Weird Sound
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 03-24-2006, 10:13 PM   #1
RHA1583
Weird Sound
When i start my jeep up in it starts up fine, then right after it starts there is a weird, high pitched, squealing noise. i have no idea what it is and it just started doing this, please help.
'04 Red TJ Sport, Light Bar w/ 4 Hella Comet Halogens, Black Tube Bumpers, Tinted Windows
2'' Procomp Suspension Lift
32'' BFGoodrich Mud Terrain on Black stainless rims
Alpine CDE-9845 Head Unit
Infinity Kappa 462.7cfp Dash Speakers
Infinity Kappa 52.7i Sound Bar Speakers
RHA1583 is offline   Reply With Quote
Unread 03-24-2006, 10:21 PM   #2
Stu Olson
Stu Olson's Avatar
First guess is your serpentine belt (aka., fan belt). If they get a little loose, they will squeal.
More info, from you, is needed.
1. Does the squealing stop after a bit?
2. If you turn on the A/C (or defroster), can you cause it to squeal?
3. Did you have any recent work done on your TJ?
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Unread 03-24-2006, 11:39 PM   #3
ixl4
1. Serpentine Belt
2. Squirrel
DR. Z MUST BE STOPPED Club Member # 1
CJC website: www.chicagojeepclub.com
2000 Sport Manual.
Mods: RE 3.5 / JKS 1.25" BL / M.O.R.E. 1" MML / Rough Country Adjustable Trackbar / Dunlop Rover 33s Cragar 397 Soft Wheels / Winch / Nates4x4 Front Bumper & Rear w/ Tire Carrier / RE .75" Spacers / P.O.R.C. SYE / RE CV DS / Nth Degree Adjustable Rear Upper Control Arms / SkyJacker Front and Rear Lower Arms
ixl4 is offline   Reply With Quote
Unread 03-25-2006, 08:30 AM   #4
uglyprimate
Water pump or fan clutch. Check fan for excessive play.
Jeep Action Magazine, now available in the USA.
His: 2000 Sport TJ, OME, 3.73's, 31x10.5 ATKO, Trash Loc
Hers: 2004 Unlimited, Arizona pinstriped and Moab deflowered.
uglyprimate is offline   Reply With Quote
Unread 03-27-2006, 09:06 PM   #5
RHA1583
its really weird in the morning or first time i start for the day it squeals and then only if im at school for around 8 hours will it do it again.
