#1 | |
Weird reverse clunking noise
Lately I have noticed when I turn and back up, I hear a clunking noise coming from the rear of the Jeep. It only happens when I turn, not when going straight. Anyone else have this happen?
Thanks Matt
#2 |
Anyone????????????????????
#3 |
I had a clunk when backing up after installing my lift. Turns out I did not have my rear control arm torqued enough.
2006 TJ, 4.0 Auto, Dana 35, 3 " of lift with OME 932-941 LD Springs w 3/4" spacers, OME N66-N67 Shocks , 32-11.5 BFG TA KO, MB 15" Predator Wheels, SRC Front and Rear w tire carrier, Rocker Side Armor, True Speed Calibrator, JKS Quickier Discos, Soft Top, 6" Canyon Flares, 9,000 lb Chicago Electric Winch/ HF Universal Winch Mount, B&M Remote Auto Transmission Filter, B&M Auto Transmission Temp Gauge, Aussie Locker up Front |
#4 |
Do you have a locker? Please fill out your jeep info, it helps us know what your setup is.
My Jeep Is For Sale! |
#5 | |
Done................. No locker |
#6 |
Check/tighten your rear trackbar and your track bar relocation mount (if you have one) I bet that fixes it.
01 TJ Sahara 4"short arm/rear gas&tire carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg 66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg 93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg 1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg 99 escort zx-2 my favorite lil gas "sipper" (who cares)lol USMC "Semper Fidelis" |
#7 | |
You may have problems with the spider gears in the differential. |
#8 | |
Sometimes 1 sometimes more than 1 |
#9 | |
In park, rotate one tire.-- 2) Try blocking one tire, In neutral, rotate the other one.--- Check all the things that have been suggested. Let us know how it goes. |
#10 |
2004 wrangler sport, stock, automatic
I also have a wierd clunk in my wrangler. It has24000 miles on it. It is an automatic stock and it happens when i transition between reverse and drive. and i can tell its not the transmission. It also happens once in awhile turning around sharp corners when starting out.
#11 |
clunk
I have the same problem on a 2004 wranler sport with 24000 miles on it. It is an automatic same exact symptoms
#12 |
Mine is manual, I'll check this weekend and let ya know
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
