Weird Problem... Weird fix... - JeepForum.com
post #1 of 5 Old 01-07-2007, 12:34 AM Thread Starter
1BadJeepX06
Heard some clankin underneath the Jeep tonight during acceleration and slowing down (downshiftin).. Never noticed it before (somethin new to me).. Knew I had somethin goin on under there.. After about 10 minutes of lookin around with some light I saw a spot where my exhaust pipe was taggin the side of my oil pan where it makes the 90 degree turn towards the motor. It only sat about 1/2 an inch away from the pan while resting.. I debated on what to do... Finally, I took a wrench and pried the pipe away from the pan.. It moved a good inch. Problem solved... No more taggin'... Any of you has this problem? I was dumbfounded on how this could have happened..
Also - Side note on something I noticed and couldn't fix.. I noticed on passenger side of the front axle where the axle itself comes out of the tubing, there was a very very very slight leak of fluid. I'm assuming there is a seal going bad in the axle, but this doesn't make much sense after only 13,000 miles.. Any of you had this problem, and I can put off taking it to the dealer until my convenience ehh? OR should this get immediate attention??
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #2 of 5 Old 01-07-2007, 12:16 PM
Mattholomew
Only 13,000 miles? I would take it to the dealer for anything that upset me about my brand new vehicle.
The leak could be from a grease fitting. There are only a couple of these on your front end, invest in and refer to a Chilton's or Haynes repair manual.
Mattholomew is offline
post #3 of 5 Old 01-07-2007, 09:40 PM Thread Starter
1BadJeepX06
Well, the problem persisted with my exhuast pipe hitting the oil pan... I climbed back underneath and further examined my options. HELLO!! Turn out, where the exhaust pipes bolt to the manifold (where the doughnut gaskets are) the bolts were loosened up a bit.. I threw a wrench on them and BAM! Problem solved! Simple and easy. Didn't think that would be my problem at all.. Not sure how they got loose, but oh well..
DH
post #4 of 5 Old 01-08-2007, 08:37 AM
Combatsylvania
its always a good idea to let the dealership documents these issues, especially on such a young jeep. makes you wonder what else wasnt tightned to spec.
mine came with NO grease on all the steering components.. dry as a bone...
Combatsylvania is offline
post #5 of 5 Old 01-08-2007, 08:59 AM
bee guz
mfg
They build cars so dam fast, that there is always something loose, not always the same piece on every vehicle, but enough to look around under a new vehicle.
I got a new chevy plow truck in 05, and whenI brought it home, I slid under, the front rear was down a pint, and the rear down a quart, the inside of the muffler was loose, and ratteling, and the front end was never greased, so it pays to slide under and take a look.
Whenever I buy anything I spend some time underneath, I like to get to know what I missed when I bought it, and you always miss something, after owning hundreds of cars, (I buy one at a time and sell them after they are right) its become automatic, and 4wd's just make it easyer, to get under...
bee guz is offline
Weird Weird Electrical Problem garr79 YJ Wrangler Technical Forum 2 07-16-2007 08:30 PM
Weird problem Grubbi TJ Wrangler Technical Forum 5 03-20-2007 01:36 PM
Weird problem itsnotaheep TJ Wrangler Technical Forum 3 06-25-2006 07:16 PM
Weird Problem, please help bran_276 TJ Wrangler Technical Forum 6 06-25-2004 07:10 PM
Weird Problem???? tufmar YJ Wrangler Technical Forum 6 09-25-2002 01:41 PM
