Weird noise when the clutch pedal is pressed - JeepForum.com
post #1 of 3 Old 01-29-2011, 08:52 PM Thread Starter
stogie25
stogie25's Avatar
I am posting this to help anyone that may have a similar problem in the future.
I had a weird noise when I depressed the clutch pedal. It was intermittent, and seemed to come and go with bumps. I figured it was a throwout bearing and was mentally bracing myself for a long weekend under my '97 TJ.
I crawled under for an exploratory mission not figuring I would see anything out of place, and was very surprised when I noticed a small gap between the transmission and the motor. It turns out that one of the bellhousing bolts had backed out and was gone. After sourcing the bolt and installing it the gap was tightened and the sound was gone. My Jeep is back to normal.
I got very lucky. I could very easily have been taking the tranny out when I found the missing bolt. This proves that a good visual inspection is the first step to troubleshooting and gives others something to look for if they experience similar symptoms.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #2 of 3 Old 01-29-2011, 09:00 PM
wushaw
Rockin jeep
wushaw's Avatar
I take it you re-secured the rest of the bolts while you were there?
wushaw is offline
post #3 of 3 Old 01-29-2011, 09:02 PM Thread Starter
stogie25
stogie25's Avatar
Yes I did. I gave all of them a good pull with the wrench. I used a little loctite on the replacement one as well.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
Weird - tach goes to zero when brake pedal pressed (engine still running) Mark_ZZ3 YJ Wrangler Technical Forum 2 10-12-2010 10:37 AM
Grinding noise when clutch pedal pressed fran87yj YJ Wrangler Technical Forum 1 02-20-2009 07:56 AM
clutch pedal squeeks when pressed trav_k1234 TJ Wrangler Technical Forum 3 11-27-2008 05:43 PM
Clutch Pedal weird noise in 2005 TJ 6spd? xe1xzq TJ Wrangler Technical Forum 13 08-25-2005 02:57 PM
Clutch pedal clicks when pressed FLMarine TJ Wrangler Technical Forum 11 03-17-2004 10:58 AM
