Weird noise coming from Jeep - JeepForum.com
post #1 of 7 Old 07-04-2012, 01:57 PM Thread Starter
TaylorJeffreyJR
1998 Jeep Wrangler 2.5L SE, It has 131xxx miles and its making a weird noise only when the engine is under pressure while driving. not at idle or coasting.. It sounds like a baseball card in a spoke of a bicycle, and its not engine noise. Please help. We've determined its not drive shafts or differentials. its either the transfer case (NP231) or transmission (AX-5)
TaylorJeffreyJR is offline
post #2 of 7 Old 07-04-2012, 02:02 PM
Necko2529
Necko2529's Avatar
Exhaust leak??
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 7 Old 07-04-2012, 02:09 PM
George Dickel
George Dickel's Avatar
X2 on exhaust leak. I've not heard of a tranny/transfer sounding like baseball cards and working before.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #4 of 7 Old 07-04-2012, 02:45 PM Thread Starter
TaylorJeffreyJR
I do have a exhaust leak but its been there for awhile, the noise only happens while there is load on the engine like its drive line issues.
post #5 of 7 Old 07-04-2012, 03:00 PM
Necko2529
Necko2529's Avatar
That's your problem, there's more exhaust flowing through under load, and the leak is only getting bigger...
post #6 of 7 Old 07-04-2012, 03:25 PM Thread Starter
TaylorJeffreyJR
ok thank you, im going to look into fixing this next.
post #7 of 7 Old 07-01-2014, 03:53 PM Thread Starter
TaylorJeffreyJR
I never got back to this on the forum. It was my rear ring and pinion gear a tooth broke and went into my spider gears and messed some things up.
2.5l , drivetrain noise , engine noise , wrangler
WEIRD LIQUID NOISE coming from Dash when I start my Jeep! Jeep-E JK Wrangler Technical Forum 16 06-01-2012 08:19 PM
Weird noise coming from the Back 99TJNC TJ Wrangler Technical Forum 21 09-12-2011 08:55 AM
Help weird noise coming from TJ afusco1222 TJ Wrangler Technical Forum 0 06-28-2011 10:09 AM
Weird noise coming from transmission Darkshine TJ Wrangler Technical Forum 0 02-05-2011 10:04 PM
Weird Noise Coming from engine StormlessWolf YJ Wrangler Technical Forum 3 11-06-2008 12:36 PM
