Weird jump in RPMS in my 2.5L TJ. Bad Clutch? - JeepForum.com
post #1 of 3 Old 07-05-2013, 08:38 PM Thread Starter
Jearbear29x
I've been searching and searching but I can't seem to find any sort of thread on this already. So it would be great if anyone can help me
As of late I've been driving around and getting a weird drop in throttle when I step on the gas pedal. It doesn't happen all the time and it only drops for a half a second, just enough to agitate me and any passengers. More importantly, it makes wheeling up rocks as difficult as all hell -.-
I was thinking clutch? But I'm not really sure if a bad one would cause this problem. The only other option suggested to me was throttle position sensor. I have the brown dog motor mount lifts that have caused a little engine shake too, if that's of any merit in this situation.
So... I have no idea.
Any ideas? Similar issues?
2.5L
3.25 RC Suspension Lift
Jearbear29x is offline
post #2 of 3 Old 07-05-2013, 09:49 PM
Pkauf123456
Your title says weird jump in rpms and your post says weird drop in throttle. I'm not understanding what your symptoms are. Are you losing power while having a simultaneous increase in rpms? If the answer is yes, That could be a slipping clutch. If the clutch is letting go it could be caused by a couple of different things. The first thing I would look at is an oil leak because these clutches hold up pretty well unless they are really abused.
Pkauf123456 is offline
post #3 of 3 Old 07-07-2013, 04:19 PM Thread Starter
Jearbear29x
Any other ideas? Bumpbump!
2.5L
2.5 , clutch , drop , manual , tj
