weird idle - JeepForum.com
post #1 of 4 Old 09-30-2004, 06:46 AM Thread Starter
bcridez
weird idle
Today i got up and hoped in my jeep, when i went to turn the key my jeep idled up around 15-1700 rpm. If i put it in reverse, drive, or any other gear it goes to normal, but in park and neutral it idles high. It is a 97' w/4.0L
bcridez is offline
post #2 of 4 Old 09-30-2004, 09:16 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Sounds like the TPS (throttle position sensor) is bad.
Wheelin98TJ is offline
post #3 of 4 Old 09-30-2004, 10:37 AM
ONE JEEPBRO
ONE JEEPBRO's Avatar
Had the same problem, replaced mine last week no problems now!
JEEP: 2004 SILVER WRANGLER RUBICON
MODS: 4.5 RE SUPERFLEX / 33inch SSR'S / WARN REAR BUMPER / JEEPERS & CREEPERS T-BODY / J&C DUAL BATTERY SYSTEM / J&C FRONT & REAR DIFF GUARD / WARN XD9000i WINCH & RECOVERY GEAR / ARB BULLBAR / PSC FULL ROLL CAGE / L.E.D TAILLIGHTS / IPF 930 SUPER RALLY LIGHTING / COBRA 75 WX ST CB / POWER TANK PT-10 OBA / TOM WOODS C/V / GARMIN 60CS GPS
CURRENT PROJECT: Nth DEGREE ARMOR INSTALL
ONE JEEPBRO is offline
post #4 of 4 Old 10-03-2004, 09:08 PM Thread Starter
bcridez
thanx for the replies
you all where right. the tps sensor was bad
bcridez is offline
4.0 has weird idle at start up and then goes away 488TJ TJ Wrangler Technical Forum 11 05-11-2009 04:36 PM
weird 92 YJ idle 92wrangler YJ Wrangler Technical Forum 5 12-01-2006 08:12 AM
Weird Idle 1994Wrangler YJ Wrangler Technical Forum 1 12-28-2003 09:04 PM
weird idle Meister_jeep YJ Wrangler Technical Forum 6 12-16-2002 10:00 AM
Low/weird idle on 95 YJ 2.5L goofus YJ Wrangler Technical Forum 2 09-25-2002 10:53 AM
