Weird Humming sound when engine turned off - JeepForum.com
post #1 of 8 Old 06-07-2007, 11:47 AM Thread Starter
Jeep'nSon
Hey all, have a question maybe you can help. 2005 Rubicon Unlimited. When I turn off the engine I hear a "humming" sound that lasts for approx. 3-5 seconds. I can't determine if the noise is coming from under the hood or from the rear. Has anyone else had this issue, any ideas what it might be. I only hear the noise after the key is off and the engine has stopped running.
Thanks,
Jason
Our New Jeeps: 1963 CJ-5 w/ Buick V-6, and a 1969 CJ-5 w/ Chevy 327 (275 h.p. whoo hooo!!), both run but also need a ton of work.
My Old Jeep: 2005 Unlimited Rubicon, ARB Bull Bar, Warn 9.5xp winch, Warn Rear Tire Carrier, Rubicon Express 3.5" SuperFlex lift, 285/75/16 BFG MT's
Jeep'nSon is offline
post #2 of 8 Old 06-07-2007, 11:49 AM
Chris @ GATR
Chris @ GATR's Avatar
Could be the ABS. All my Land Rovers did the same thing, but constantly.
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #3 of 8 Old 06-07-2007, 12:19 PM
Rocky529
Rocky529's Avatar
Are you running your a/c after you turn off the engine? If so it is just your condenser.. normal.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 8 Old 06-07-2007, 01:58 PM
Combatsylvania
rememebr the AC runs when your defrost vents are selected to help pull moisture out of the air..
whatever it is, i dont think its a problem
2006 TJ SE - Does what I want it to do.
Combatsylvania is offline
post #5 of 8 Old 06-07-2007, 02:04 PM
PackMan
PackMan's Avatar
Location: Home of the Super Bowl XLI Champion Indianapolis Colts
No ABS on Rubis.
2004 Rubicon 5spd
33x1250x15 BFG MT on A/R Teflon Chamber (3.75" BS)
2.5" Suspension Lift / 1.25" BL
OME 2.5" (930 front, 942 rear), Daystar 3/4" front spacers, OME N66/N67 shocks, JKS adj track bars, JKS BBL, JKS BMML, really cool toddler booster seats,
Jeeperman bumpers and rockers, IPF 968, Cobra 75WX CB, sPod switches, Cheerios under the rear seat, Skid Row engine and steering box, MORE steering
shaft lift, crayon marks on the sport bar, Napa SC2928 steering stabilzer, Warn xd9000i winch, something that smells bad on the passenger side rear
fender that a child probably had something to do with, HiLift jack, a .357 Magnum S&W, and an Indianapolis Colts SBXLI World Champion window sticker.
PackMan is offline
post #6 of 8 Old 06-07-2007, 02:32 PM Thread Starter
Jeep'nSon
Nope, A/C not on, not even defrost. We haven't had any defrost issues here in Southern California for a few months.
Thanks,
Jason
post #7 of 8 Old 06-07-2007, 03:42 PM
solarpower
fuel pump maybe??? possibly even your locker pumps.....but I think you would have other issues if it was your locker pumps.
fuel pump is in gas tank.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #8 of 8 Old 06-07-2007, 03:45 PM
juiceparn
I have an JK 4DR that does that as well?? Regardless of accessories running. It's sounds similar to an antenna retracting I'll check with the dealer tomorrow to see if they can tell me what it is.
juiceparn is offline
4.0 makes dripping sound after engine turned off... JaredSS TJ Wrangler Technical Forum 8 06-18-2014 10:37 PM
Draining Sound after Engine is Turned off??? 92yjokc YJ Wrangler Technical Forum 9 09-16-2008 12:17 PM
Weird Humming Noise from engine? Darkkiller922 YJ Wrangler Technical Forum 14 11-08-2006 11:48 AM
Weird sound coming from engine..... kampoyj YJ Wrangler Technical Forum 12 12-01-2005 10:12 PM
You've never heard an engine sound as weird as this LandRover YJ Wrangler Technical Forum 20 05-18-2005 10:44 AM
