Quantcast weight of rear bumper, tire carrier, and 33" tire..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > weight of rear bumper, tire carrier, and 33" tire.....
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Old 05-28-2006, 11:05 PM   #1
ClemsonJeepGC
is it enough to make the rear of my jeep go down 1"?
I actually want that too happen to get rid of the "rake" and get some wheel base back.
[COLOR="DarkGreen"]1998 Green Sahara - Rusty's 3", 33x12.50 BFG AT, RE Track Bar, Gambler wheels, 1.25" spacers, home made window roll, rear olympic rockslider bumper, Kenwood KSC-SW1 Sub[/COLOR]
[url]http://community.webshots.com/album/549011933rUkFBJ[/url]
2004 Black Tacoma TRD
ClemsonJeepGC is offline   Reply With Quote
Old 05-28-2006, 11:08 PM   #2
bryans98tj
Depending on many factors (brand of tire, carrier, springs, wheel material) will tell how much it drops. I can say it is a safe bet though it will drop an inch. Get a buddy with a tape measure and put it on the wheel then stand on your bumper now. It will give you an idea.
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote
Old 05-28-2006, 11:29 PM   #3
ClemsonJeepGC
its rustys springs, this item http://www.quadratec.com/products/12052_402_07.htm
and a stock gambler wheel with a 33x12.50 BFG AT.
How much can expect all that to weigh?
Old 05-28-2006, 11:32 PM   #4
ClemsonJeepGC
"Accepts up to a 35" spare tire. The 2" receiver hitch is intended for recovery purposes only. Tow rating not applicable."
Does this mean I can't tow a small trailer?
Old 05-28-2006, 11:36 PM   #5
bryans98tj
No not really. It just means that they won't be held responsible. Quite a few bumpers out there either have no rating or a very low on. It's mainly a liability thing. People are always trying to tow heavy things with Wranglers so companies cover themselves. I have an Olympic and I got that one because it is rated to pull and I have a small utility trailer for dirt bikes.
Old 05-29-2006, 02:29 PM   #6
pismo61
I had a jeeperman bumper with tire carrier 90 lbs.-33x12.5 tire 53 lbs. and the wheel was 25 lbs. Total 168 lbs.
1996 Red two door.
pismo61 is offline   Reply With Quote
Old 05-29-2006, 03:42 PM   #7
ClemsonJeepGC
I dont think my jeep would go down at all with only 168lbs. I'm thinking about switching the back to 2" springs, but I worry the front would sit higher since I don't have a winch.
Old 05-30-2006, 05:32 PM   #8
spyderbyte
Why not put a spacer in your front springs? I'd rather raise the front an inch than drop the back.
Just a thought
Spyderbyte
spyderbyte is offline   Reply With Quote
Old 05-30-2006, 06:03 PM   #9
Max1775
Just a thought
Spyderbyte
Damn good idea, was thinking that myself...
05' Rubicon Unlimited, 33" BFG M/T's
[CENTER][SIZE="5"][COLOR="DarkRed"]SAW 'EM OFF![/COLOR][/SIZE][/CENTER]
Max1775 is offline   Reply With Quote
Old 05-30-2006, 07:28 PM   #10
ClemsonJeepGC
I dont want a spacer in front for two reasons.....
1. If I lower the back, I will get some wheel base back. I dont like how my rear axle moved forward (looks funny)
2. If I raise the front, I risk having to get longer control arms because of Caster (I may already need to....haven't decided yet....Ill see how my new RE track bar does first) EDIT: The RE Trackbar helped alot.
I can live with out being able to disco (if that is the only way the rear would rub) and I could always get a 1" BL.
Old 06-07-2006, 11:38 AM   #11
ClemsonJeepGC
Dare I ask what yall think about spring clamps to lower my jeep 1" in the rear? Of course, this would be a very bad idea when flexing, and it will make the ride stiffer I would think.
Do yall know what springs I could put in the rear that when combined with Rusty's 3" up front will make my jeep level (keep in mind I dont have weight up front from a winch). The rear is 1" higher than the front.
Glock Forum
