Quantcast Weenie horn on the Jeep - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Weenie horn on the Jeep
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-30-2007, 01:53 PM   #16
DJ Daddy
Looks like an Art Car.
[SIZE="2"][CENTER][B][FONT="Comic Sans MS"]Howdy from Ron in Rural Kansas City[/FONT][/B][/CENTER][/SIZE]
DJ Daddy is offline   Reply With Quote
Old 11-30-2007, 03:11 PM   #17
Wheels4186
200PSI
1/2" ID line
It gets the job done
Dave
www.patriot-customs.com
04 Patriot Blue TJ- DAILY DRIVER/WEEKEND WARRIOR D-30/60 7.5" of lift, 38's, bumpers, cage, OBA, winch, armor, tube fenders, 2000W Stereo, etc.
Wheels4186 is offline   Reply With Quote
Old 11-30-2007, 03:13 PM   #18
mike68
i agree, when i first honked the horn on my 04 rubi, it sounded so wimpy.
check out my club! www.myspace.com/viking4x4club yellow jeeps club member #68
./l ,[_\_\ ],
l---L – ()lllllll()-
()_) ()_)--o-)_)
mike68 is offline   Reply With Quote
Old 11-30-2007, 03:17 PM   #19
ieatchickens
Originally Posted by Theboogieman
I call my horn the roadrunner, "beep beep"
I actually like the sound of the old military Jeeps with their beep beep sound.
My 98' horn sounds like it should be in a Buick LeSabre. Wish I had a high pitched beep beep.
98' SE, Chili Pepper Red, grizzly wheels, 126AA/103AA to 129AA/105AA coil swap, 3/4" spacer, 31 Yoko Geolander AT, soft top, rear view mirror turned upside down, door straps twisted, rubicon wipers, optional factory rear sway bar, doors & top on.
Low Output 4 Cylinder Jeep Club Member #1
06' Grand Cherokee Limited, 4.7 liter V8
99' Grand Cherokee Limited, 4.7 liter V8
ieatchickens is offline   Reply With Quote
Old 11-30-2007, 03:28 PM   #20
chadsmeltzer
chadsmeltzer's Avatar
Originally Posted by Jerry Bransford
.... If I was in Texas, I'd just mount it on the hood to the rear of the steer horns and be done with it.
I mounted mine in between my lights on my lightbar
You can kinda see it here
Not as loud as I would like, but much better then stock, and people love it
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline   Reply With Quote
Old 11-30-2007, 03:55 PM   #21
1CleanTJ
here's a video of a local guys jeep, its a cherokee but if you can find a spot to fit it in a tj it would be sweet
http://www.youtube.com/watch?v=QdI-C0IrbrQ
1CleanTJ is offline   Reply With Quote
Old 12-21-2007, 12:56 AM   #22
Panici
(O|||||||O)
Panici's Avatar
I wanna rig up a setup to have dual horns. (on a selectable switch)
one mode would allow the wheel horn to be an old CJ/Willys "Beep Beep" horn, and the other switch position would turn that same steering wheel into an activation for a truck air horn
_______
|_Jeep_|
(OlllllllO)
590nm Jeep TJ Build+Life
Panici is offline   Reply With Quote
Old 12-21-2007, 04:32 AM   #23
Justin Brimm
If you really want to go nuts on the horn, try this (I wouldn't though): http://www.youtube.com/watch?v=TiWNw0A1Ijg&feature=related
Personally, I do want a train horn in my Jeep, but I want it on an actual pull-line, if only because I want the stock horn for little warning beeps, like when someone cuts a little too close, but I would like the train horn for actual "watch the **** out!" warnings.
For whatever reason, it's popular here for people to try and make left turns in intersections when it's green, but to try and beat oncoming cars instead of just wait another ten seconds and not get killed. What's worse, is you can just tell when they're about to pull out and you have a 1 second window to lay on the factory horn and flash the brights to stop them from pulling out right in front of you. I really think a train horn (or other super loud one) that also flashed the brights when used, would be a lot safer.
Justin Brimm is offline   Reply With Quote
Old 12-21-2007, 04:45 AM   #24
raco
I have the same horn as the wolo but called a different name. The stock horns and the air horns blow when I honk. I think I paid $35 for them on ebay, I put them under and behind the front bumper facing down and forward. Great investment and is very loud for a compact air horn. I would love to have an air tank and a nice train horn but very impractical for me.
raco is offline   Reply With Quote
Old 12-21-2007, 08:44 AM   #25
Los
Originally Posted by dogbluedrummer
That's not bad at all but is there a delay from the time with these small air horns?
'04 TJ, RE 4.5, 33 BFG MT's, ARB F/R, LoD F/R, D30, S35
Los is offline   Reply With Quote
Old 12-21-2007, 02:20 PM   #26
chadsmeltzer
nope, my 418 blows right away
Old 12-21-2007, 02:41 PM   #27
djt283
You can all have the best of both worlds you know. I wired my truck air horn setup to a solenoid valve that is also activated by the steering wheel horn button. I also replaced the stock baby horns with a slightly better one (but still a "normal" horn).
Then I wired everything to a 3-way switch on my dash. I can now select truck horn/normal horn/no horn.
The best part about the air horn is whenever it's at the shop/car wash and someone presses it inside it scares th $%#& out of them. When I had my tires mounted I sat in the waiting room listening to my horn blow for ten minutes while everyone took turns playing with it.
djt283 is offline   Reply With Quote
Old 12-21-2007, 05:10 PM   #28
BM20
i just swapped my stock 03 horn with a dual horn out of an 05 caravan. Its just a normal dual horn but it sounds so much better. I didnt want to switch to the air truck/train horns so this works good enough for me. with a little modification, it fit in the same spot as the original one.
RUBICON Tomb Raider #953
With a Few Extras...
BM20 is offline   Reply With Quote
Old 12-21-2007, 06:06 PM   #29
chewTJ
Originally Posted by djt283
My favorite is getting my friends to take a look at something on the jeep and then blasting it while they least expect it...makes me laugh every time.
Man if you were my friend I'd kick ya right in the nuts. :j/k:
[JEEP]
OllllllO
Blue jeep club member #248Low output Jeep club member #279MN jeeper member #3
Originally Posted by BlackBellamy View Post
...now hush, I'm off to install a throttle body spacer and a K&N filter for that super performance boost!
chewTJ is offline   Reply With Quote
Old 12-21-2007, 06:20 PM   #30
chewTJ
Originally Posted by majormadmax
You say that like it's a bad thing! So we like a little flair on our Jeeps, so what?
Cheers! M2
i think i just threw up a little in my mouth.
[JEEP]
OllllllO
Glock Forum
