This weekends Jeep problems (radio and belt) - JeepForum.com
post #1 of 3 Old 05-23-2010, 06:57 AM Thread Starter
AppFan
My factory radio will play for about 5 seconds and cut out (just the sound, it still has power and all the buttons still operate). Any ideas or time for a new head unit? I'd rather not spend cash on it as it's one more thing for people to steal and it's just a weekend toy, not my daily driver. Though it would be nice to have an iPod plug...
Also, when I started it this morning I had some squeaking under the hood. It sped up with the engine and went away as it warmed up so I'm guessing I'm about to be replacing a belt?
Thanks in advance
AppFan is offline
post #2 of 3 Old 05-23-2010, 07:17 AM
djt283
djt283's Avatar
Not sure about the radio, but as far as the belt my guess would be a pulley. You can easily check the belt for wear, and even if it's ok it's not a bad idea to replace it considering how easy it is.
I had the same type of noise...squeaked when cold then went away. Turned out to be the idler pulley. You can easily diagnose the pulley by hitting the bolt/bushing with a squirt of wd-40...if it doesn't squeak you found the pulley that needs to be replaced. (some people might argue with this, but just don't get whatever you use on the belt)
The idelr pulley and belt should take 30 minutes to replace. Just make sure you sketch the belt routing out or print a diagram before removing it.
djt283 is offline
post #3 of 3 Old 05-23-2010, 07:21 AM
cidd
Just give your local bone yard a call see if they have one there cheap and if someone steal it no biggy. I picked up one for mine the cd player didnt like giving back my disc so I bought one for $25 from my local yard they had 30 of them guy pointed to a pile and said pick one and try it out if it dont work bring it back and try agine.
cidd is offline
belt , radio , serpentine belt
What I've been doing the last few weekends (w/pics)... XJeffro TJ Wrangler Technical Forum 19 02-19-2008 05:44 AM
Belt Problems??? dwillz07 TJ Wrangler Technical Forum 4 01-09-2008 05:14 PM
belt problems 951 freak YJ Wrangler Technical Forum 1 07-27-2006 11:05 PM
This Weekends Project HVACman TJ Wrangler Technical Forum 12 03-13-2006 10:16 AM
fan belt problems DieselWrangler TJ Wrangler Technical Forum 8 03-05-2006 07:42 PM
