Weak HEAT - Please help - JeepForum.com
post #1 of 3 Old 05-17-2011, 07:14 AM Thread Starter
mreilly4
2000 Jeep Wrangler, 2.5L 4 cyl
My heat was gradually becoming weaker (less hot). I brought it to a shop and my mechanic said it needed coolant/antifreeze. He flushed the coolant system and refilled it. The heat was working great. 500-1000 miles later the heat is losing steam again. It's barely warm enough to defog my windshield. Any thoguhts on how I might fix this myself, if at all possible? Thanks!
Mike
mreilly4 is offline
post #2 of 3 Old 05-17-2011, 07:27 AM
notmyj
Well, for starters, you should have posted this question here, http://www.jeepforum.com/forum/f9/
More on topic, when the engine is cool, pop the rad cap off and check the level. If its full, put the cap back on and start the engine. When it gets hot, see if the heater hoses on the firewall are hot. If one is significantly hotter than the other (with the heater on "hot" and fan on low) then you may have a plugged heater core. If both hoses are hot, then you may have an issue in the heater box with the blend door or its motor or the controls. I don't know the TJ's that well, but that should give you a place to start.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 3 Old 05-17-2011, 07:28 AM
C2U5H
C2U5H's Avatar
Hmm, maybe he didn't flush the system well enough? I was having problems with heat with my 4.0L, and I needed to replace my radiator due to a cracked pinch seam along the top. Replaced the radiator after flushing the entire system with a garden hose—which includes sending water down the inlet and outlet hoses to get the heater core in your flush. I had a bunch of weird colored stuff come out. Maybe drain the radiator, disconnect the outlet hose to the heater core and flush again? Or take it back to your mechanic and explain the problem, see if he'll flush again for free (doubt it).
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
antifreeze , coolant , Coolant leak , heat
Weak Jeeps Hardt114 General Discussion 17 03-06-2009 12:54 PM
Weak US Dollar Keith General Discussion 16 10-19-2007 01:17 AM
Your KungFu is weak ian-X General Discussion 8 10-12-2003 01:32 AM
Weak velcro on soft top NJJeeper General Discussion 3 12-18-2002 10:28 AM
