weak frame in the 97 tj's - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > weak frame in the 97 tj's
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-26-2011, 01:40 PM   #46
j_niko
2009 JK Wrangler
The frame on my 97 looks pretty decent. My problem area is where the frame mounts connect to the tub. Aside from a new tub, I'm not sure what I can do for it.
2000 - Sahara
1997 - Sahara
j_niko is offline   Reply With Quote Quick reply to this message
Unread 09-27-2011, 12:56 AM   #47
bikerman02
My 02 is rusting at the steering box mount really bad water gets in there and just sits rusting it out. I have a buddy with a 97 different frame mount for the steering box his even has a hole in the bottom so it can drain. I wish jeep would have kept this but nope they had to change a good thing.
bikerman02 is offline   Reply With Quote Quick reply to this message
Unread 09-27-2011, 01:40 AM   #48
lil-jmart13
Could you close up the holes in your frame? To keep out all the mud and stuff??
THE RUBBER DUCK! SOLD :(
2000 JEEP TJ - mostly stock - daily driver
MEAN GREEN
1997 JEEP TJ SAHARA - project mean green!
WTB: TJ HALF DOORS OR TUBE DOORS!!! PM ME!!
NIGHTCREW
-#35-
lil-jmart13 is offline   Reply With Quote Quick reply to this message
Unread 09-27-2011, 05:53 AM   #49
97TJSPRT
what about adding instead of closing? can we just drill a hole underneath the frame where we want water to drain?
*******q[ _\ _\_ ]p********
******._(|||||||)_.******
******III"""""'''''""""'"'III******
Zombie Outbreak Response Unit #279
97TJSPRT is offline   Reply With Quote Quick reply to this message
Unread 09-27-2011, 02:55 PM   #50
lil-jmart13
Yeah that's been done, but why can't you seal your frame up with thin sheet metal just enough to keep most of the mud out?
MEAN GREEN
NIGHTCREW
-#35-
Unread 09-27-2011, 04:18 PM   #51
97TJSPRT
i like that idea too, wire brush the frame down and just a little weld to hold it there then paint/undercoat it back in
Unread 09-27-2011, 04:19 PM   #52
lil-jmart13
Is there any reason you can't do this?
MEAN GREEN
NIGHTCREW
-#35-
Unread 09-27-2011, 04:46 PM   #53
solarpower
you have 3 choices..
1) do nothing. Great option for people who live in California and Arizona.
2) Seal it up 100%. Of course this is will not let any moisture out and it will still rust through...unless of course you are able to remove ALL corrosion currently on the inside of your frame, then paint and coat it completely. Good luck. You will also have to come up with another way of mounting a bunch of stuff to your frame...like your T-case skid.
3) Drill holes from the bottom. Flush out your frame every month or so and after you go wheeling. The inside of your frame will now be in the same or better condition that the outside.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline   Reply With Quote Quick reply to this message
Unread 10-02-2011, 11:36 PM   #54
saxart
I'm surprised nobody makes a pre-cut gusset-plate that could be welded to the outside (rear) of the frame to strenghten it BEFORE it gives way to rust.
If it started at the rear of the body-mount that's just behind the transfer case skid, it could extend back UP the curve of the frame to the spring-perch for the rear axle and encompass the area that cracks and pulls away, thereby fixing the problem for good.
Once the frame cracks and "moves" it would be pretty tough to get it back to the exact location to fix it, but if you perform this mod BEFORE any cracks happens, you'd buy your frame another 20+ years.
Anyone?
I intend to live forever. So far, so good.
'99 Wrangler Sport: 2.5" Old Man Emo lift and shocks, adjustable trackbars, Quick-Disko sway links, rollin on 31" BFG A/Ts
saxart is offline   Reply With Quote Quick reply to this message
frame , frame patch , frame repair , frame rot , Frame rust
