weak frame in the 97 tj's - Page 2 - JeepForum.com
post #16 of 54 Old 09-14-2011, 09:12 PM
EricsGreen98Tj
My frame was that bad too. I found a used frame from a guy on here cheap and swapped it in. I put a 97 frame on my 98 and EVERTHING was the same. If its that bad there then just think how bad it is on the whole inside of the frame....
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #17 of 54 Old 09-14-2011, 09:43 PM
3fifty
That was my thought process. Im glad I went with it.
Once we got the tub off and started looking around I realized that even if I would have just patched the rear passenger LCA area where it separated (like yours is about to) I would have had to deal with the other side shortly after.
When we peeled the cross member out of the frame along with nutserts I realized just how bad it was overall.
A few weeks later we went on a trail ride and another new TJ owner had his belly pan rip the nutserts out of the frame during the ride. I was glad it wasnt me even though we got him home safely.
I found a good frame, called some good friends and we had it swapped over with 23 hours of labor and some odds and ends fixed as well.
Find a frame and swap it.
The only difference in frames are between 4 and 6 cylinders.
3fifty is offline
post #18 of 54 Old 09-14-2011, 09:45 PM Thread Starter
97TJSPRT
how much did the swap cost you?
*******q[ _\ _\_ ]p********
******._(|||||||)_.******
******III"""""'''''""""'"'III******
Zombie Outbreak Response Unit #279
97TJSPRT is offline
post #19 of 54 Old 09-14-2011, 09:46 PM
hustler905
I think 97s are "weaker" because they're simply older.
These threads scare the **** out of me, and invariably result in me checking every inch of frame with a screwdriver like a crazy man, looking for soft spots.
hustler905 is offline
post #20 of 54 Old 09-14-2011, 09:53 PM
3fifty
I didnt keep track.
Around $800 with a junkyard frame, fluids, misc stuff breaking, flap discs, paint, and food/beer for my buddies.
Inspect your brake lines and fuel lines to see if you can reuse them. They are relatively cheap to replace and very easy with the tub off. They are probably rusted as well.
With the tub off its also a great time to raise your body mounts and fix the shock mounting problem in the rear.
3fifty is offline
post #21 of 54 Old 09-14-2011, 09:57 PM Thread Starter
97TJSPRT
i dont have the time or resources or honestly the knowledge for to really do a frame swap id have to get it done for me im 19 full time student at college on the wrestling team and working
97TJSPRT is offline
post #22 of 54 Old 09-14-2011, 10:03 PM
3fifty
That sucks. You better get ready to pony some cash up.
Honestly, its not as hard as you would think. I know its very intimidating though.
3fifty is offline
post #23 of 54 Old 09-15-2011, 05:26 AM Thread Starter
97TJSPRT
like i said i already enforced the other side a few months back, i think it ran me like 300. ill do the same to this side and pray to god that nothing else is rotted
97TJSPRT is offline
post #24 of 54 Old 09-15-2011, 07:54 AM
PeteYJTJ
Toyota recalled the Tacoma for rusty frames - 1995.5-2004 or so. Jeep should have done the same. Sure, if you're in Cali it's fine, but in other areas, a Jeep that's not even 10 years old with a frame rotted through and coming apart that badly? IMHO, that's a problem.
My 99 isn't great, but it's ok. I try to stay on top of injecting oil on the inside, and sand and rust-converter on any rust on the outside.
There is a company that makes patch-frame-panels that look pretty good. http://www.jeep4x4center.com/auto-rust/
Good luck,
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #25 of 54 Old 09-15-2011, 09:54 AM
Dogbones
ive seen alot of 2006 jeeps with "like-new" frames, is it because its still relatively newish or is it because they coated them with something different? They use some nasty salts on PA roads and my frame still looks decent, only rusty thing is the muffler
Dogbones is offline
post #26 of 54 Old 09-15-2011, 10:22 AM
srlbotanical
http://www.jeepforum.com/forum/f9/fr...hread-1161491/
This is pretty common in Michigan The above thread Chronicles what happened to mine. Several other club members with different model year TJ's are having the same issue.
As stated several times, it's not a year problem, it's a design problem. Salt/mud/water can go right into that hole next to the rear tires and It has no where to go.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #27 of 54 Old 09-15-2011, 10:29 AM
Speed-Freek
Salt kills.
ASE certified tech, and welder/fabricator for hire, PM me for any of your automotive needs!
Speed-Freek is offline
post #28 of 54 Old 09-15-2011, 10:30 AM
PurpleTJ
Definitely a big deal around MI / Great Lakes area. Heres what mine looked like ~3 weeks ago before i got it back from the shop. Looks a lot better now though
Purple Jeep Club member #8
PurpleTJ is offline
post #29 of 54 Old 09-15-2011, 11:06 AM
TheMusicMan
Early model TJ frames are slightly different than later model TJs.
TheMusicMan
TheMusicMan is offline
post #30 of 54 Old 09-15-2011, 11:07 AM
jeepsus
GAH! this thread compares to being a crack addict just starting out and being caught by your parents, then they show you all these terrible picture of what you will look like in 2, 5 and 10 years after being a crack head.
i'll be outside checking my frame....again.
I am helping to fight a great cause that hit close to home, please click to read my story!
jeepsus is offline
frame , frame patch , frame repair , frame rot , Frame rust
Painting TJ's Frame...Any suggestions?? Cooneys08JK TJ Wrangler Technical Forum 38 05-08-2015 07:39 PM
TJ's Frame and Headlight Bezels Finally Painted! (PICS) Cooneys08JK TJ Wrangler Technical Forum 22 07-16-2007 12:44 PM
Is the Transmission mount on the TJ's 00-04 NV3500 centered between the frame rails? JeepRocks86 TJ Wrangler Technical Forum 4 04-15-2007 09:28 PM
Are 4.88s weak gears in TJ's? MasterCujo TJ Wrangler Technical Forum 8 03-19-2004 06:00 AM
Weak spots on frame for rear bumper mount? jedi 4x4 TJ Wrangler Technical Forum 8 10-16-2003 04:03 PM
