Way to convert open diff to limited slip? - JeepForum.com
post #1 of 4 Old 03-07-2007, 06:03 AM Thread Starter
WilliamH
Hey guys, check this out: www.phantomgrip.com .
If I understand correctly, it's a way to convert an open differential to a limited slip/locker. I haven't priced it yet, but it might be less cost that a lunchbox locker.
'06 Toyota Tacoma TRD Double cab with selectable rear locker ('06 Wrangler replacement).
'08 Yamaha FJR1300 sport/touring motorcycle with ABS and power adjustable windshield.
'06 Yamaha Wolverine 450 sport/4wd ATV.
'09 Yamaha Grizzly 550 SE with EPS, winch.
WilliamH is offline
post #2 of 4 Old 03-07-2007, 06:20 AM
CNY
They cost more that a lunch box, and their application list doesn't show Jeeps.
CNY is offline
post #3 of 4 Old 03-07-2007, 06:22 AM
jonzer12
This was a big topic with the street crowd about 3-4 years ago.
Yes it actually works, yes its not nearly as good as a quality LSD.
A magazine did a test of it a while back and showed that while it does actually work, it doesn't have nearly the strenth of a quality clutch type LSD and it did not work that well in high HP applications, if I remember correctly it actually tensions against your existing spider gears.
I wouldn't use it for offroad apps.
jonzer12 is offline
post #4 of 4 Old 03-07-2007, 06:24 AM Thread Starter
WilliamH
Yea, I looked further on their web site after I originally posted. I found it while I was trying to find some more information on limited slip differentials.
Maybe we can convince them to make them for Jeeps. At $300, they might be good for someone that wants a cheap limited slip without having to set up a ring and pinion.
WilliamH is offline
96 limited slip 98 open?????? dallass YJ Wrangler Technical Forum 15 01-21-2010 10:14 AM
limited slip or open? 1993sahara YJ Wrangler Technical Forum 3 12-10-2008 06:00 PM
Open Diff or Limited Slip??? sdlemaster TJ Wrangler Technical Forum 28 02-09-2007 09:44 AM
limited slip, locking diff open diff jeremy2027 JK Wrangler Technical Forum 13 02-06-2007 01:58 PM
open vs limited slip, which is better for offroading ? MeGAMoE TJ Wrangler Technical Forum 13 10-17-2006 11:46 AM
