Quantcast waterpump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > waterpump
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 06-18-2006, 01:10 AM   #1
DannyMK2
waterpump
ive found out the my coolant leak is coming from my water pump like i suspected. im looking to replace it and i am wondering which brand you guys have used. ive seen bosche or airtex. theres about a $40 difference in price so im wondering if its worth it. thanks
'78 Datsun 280z 5spd I6 (waitin for paint)
'84 Supra 5spd I6 (finishin up some minor body work, body kit, then paint)
'84 Supra 5spd I6 (Parts Car)
'00 TJ 5spd I6 (Daily Driver for now)
something tells me i like 5spd I6's
DannyMK2 is offline   Reply With Quote
Old 06-18-2006, 01:17 AM   #2
tjbrotha
my replacement water pump for the same problem was a Duramax from Autozone. Did this happen around 102k+ because thats where mine did.
and don't forget to wave !
97 I4 TJ SEDone 8/13/07: DPG Ultimate Suspension kit: DPG Trailgunner Coils, Old Man Emu HD Shocks, JKS 1.25" BL + 1" MML, JKS Front and Rear Adjustable Track Bars, JKS Quicker Disconnects, 31" BFG A/Ts daily driven 33" BFG A/Ts Wheelin, Personally made Hand Throttle, Airaid air filter, goin for more asap
Asking a Jeep to be fast is like asking a brick to fly.-Airborne4X4
tjbrotha is offline   Reply With Quote
Old 06-18-2006, 08:56 AM   #3
bobjp
I haven't used either of those brands, but if I were to replace my water pump I would get it from Napa and not worry.
97 TJ sport. No swaybar. ;)
bobjp is offline   Reply With Quote
Old 06-18-2006, 09:57 AM   #4
bryans98tj
I got mine from autozone and they have both held up well (had to do one in my wifes grand cherokee). If its installed right it will be fine. I really wouldn't suggest a hi flow one only because the system is not designed for it.
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote
Old 06-18-2006, 10:07 AM   #5
ThisguyhasADD
i work for napa and weather you go with the remanufactured or brand new they will both hold up....
just replaced mine on my tj at 85k
ThisguyhasADD is offline   Reply With Quote
Old 06-18-2006, 10:13 AM   #6
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Avoid cheap water pumps with their so-called "Lifetime Warranty". Sure they will give you a new one if the one they sold you fails but they're so cheaply made, they WILL fail much sooner than the OE water pump will. Is the minor cost savings worth a couple extra hours of your labor, especially when it may fail at the least convenient time when you just don't have the time to swap it yourself?
I bought an Autozone "lifetime warranty" water pump and when I took it out of the box, I couldn't believe how cheaply made it was. I returned it for a refund and bought the OE pump for $40 more... and that $40 will be more than paid for since I know it'll easily outlast the cheap Autozone pump. And Autozone gives that lifetime warranty since they're betting you'll either sell the car before it goes bad or you'll forget about the warranty and just buy another somewhere else when it fails.
There's a HUGE difference in quality between the OE and most aftermarket water pumps, be careful what you buy.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 06-18-2006, 10:26 AM   #7
farinspace
not sure what brand it was but i bought a kragen "lifetime warranty" water pump, i was pretty commited to the job as it was sunday, my old pump was off the vehical and i needed to go to work the next morning, the metal on this pump is really soft, so watch out not to strip the threads on the hose back to the heating system.
however, i am thinking that the leaking wasnt coming from a faulty pump, but rather a worn out gasket, im sure it would just require a gasket change, but it is better insurance to just replace the entire thing.
98 TJ, 4.0L I6, 5sp, 4.88 Alloy Gears, D30[Aussie Locker]/D44[Detroit TrueTrac]
33" Toyo Open Country MT, 2" BB Lift + 1" Eng./Body Lift, TW SYE + Drive Shaft
farinspace is offline   Reply With Quote
Old 06-19-2006, 11:28 AM   #8
DannyMK2
im kind of figuring mine to be the gasket as well but i really dont want to change the gasket only to find out that it was the pump. ive only got 67k on it.
Old 06-19-2006, 12:05 PM   #9
rouxbicon
Just out of curiousity, Jerry, when you say OE (which I assume to mean original equipment) do you mean genuine Jeep/Chrysler/Mopar from a dealership?
'03 red Rubi
rouxbicon is offline   Reply With Quote
Old 06-27-2006, 07:04 AM   #10
gatornut30
My water pump just went bad yesterday at 97k, I got a new one from Autozone and plan on installing it today. Before I do all that what kind of WP did you use instead of the Autozone one?
2003 Rubicon Auto, Hardtop, Viking Soft Top, 5.5" RE Long Arm lift, Spider Trax 1.25 spacers, 35" BFG M/Ts, Warn 9.5Ti Winch and BlueTorch Fab winch mount, Currie Heavy Duty steering, Currie front Anti-Rock Sway Bar, ARB locker switches, MagnaFlow Exhaust, AmpBestop power steps
gatornut30 is offline   Reply With Quote
Old 06-27-2006, 07:44 AM   #11
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
That's correct.
OE = original equipment which is available from the dealer.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Glock Forum
