#1 | |
Water Pump Replacement
I am about to change out the water pump because I think its causing some other problems. I did a squeeze test on the upper radiator hose and I dont feel a surge of water going thru as I release it. Actually I dont feel much if any difference in the pressure of the hose whether the veh is running or off. I changed the thermostat and it keeps the temp below 1/2 way on the gauge so I know that coolant is running thru the engine atleast some. I hope I am diagnosing this properly so i dont change the pump out when I dont have to. I think this is the cause of my no heat situation too. How much of a pain in the rear is changing this pump out and are there any suggestions to avoid any problems or short cuts to make my day easier???
dan 97 2.5L
#2 |
i would be suspect of your diagnosis...
if it ain't overheating, i would have no reason to suspect the pump. is the upper hose getting hot and pressurized when it is at operating temp? are the heaterhoses getting hot? i don't know all the ins and outs but i seem to recall there being some problems with the blend doors in the heater housing...that is where i would be lookin |
#3 |
all the heater stuff has been checked and ok. i just have to flush the heater core and then the water pump is the only thing left to replace or check.
#4 |
oh yeah, no the upper radiator hose is not pressuring at normal op temp....
#5 |
Demonic Jeep Freak!
If the water pump is bad you would be overheating very quickly.Maybe your new thermostat is bad like the one's I buy at Autozone.
#6 |
today I am flushing the system and the heater core. If that doesnt work and the upper radiator hose still doesnt have pressure in it.....its gotta be the pump. right???
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
