water pump "r" reverse rotation - JeepForum.com
post #1 of 10 Old 03-02-2010, 02:24 PM Thread Starter
restorod
2014 JK Wrangler
hey guys..im in the middle of a water pump install..my napa replacement pump,does not have an "r" stamped on any of the impeller fins,however the direction of the fins are going the same way,so i am good to go right?? whether there is an r on the new one or not...right?? napa says they dont know of any different pumps for a 4.0 97 tj..thanks
restorod is offline
post #2 of 10 Old 03-02-2010, 02:29 PM
2jhanna
I would go with it.
jhanna
denton county, tx
2jhanna is offline
post #3 of 10 Old 03-02-2010, 02:33 PM Thread Starter
restorod
2014 JK Wrangler
first time i even had heard of it was on this forum...but fins look to be the same direction,so guess i will go "GIT ER DONE"
restorod is offline
post #4 of 10 Old 03-02-2010, 02:38 PM
never monday
"R" can also mean right or reman
never monday is offline
post #5 of 10 Old 03-02-2010, 02:55 PM
TexanTJ
2014 JK Wrangler
Id install it and go from there. R could stand for anything like a brand, remanufactured, reproduction model, right.
Im 100% sure that it wouldnt stand for reverse. The only thing that pops into my head with a reverse flow cooling system would be a GM LT1.
The fins are going the same way so your Good To Go!.... Like a crunchwrap from taco bell
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #6 of 10 Old 03-02-2010, 02:59 PM
SilverBullot
Go for it, my replacement pump did not have an R on it either. My Jeep hasn't blown up....yet
9-11-01 NEVER FORGET NEVER FORGIVE
If a pretty poster and a cute saying are all it takes to motivate you, you probably have a very easy job. The kind robots will be doing soon.
_██_
(ಠ_ృ)
97 TJ A/C Compressor for SALE!
SilverBullot is offline
post #7 of 10 Old 03-03-2010, 04:55 PM
lupinsea
lupinsea's Avatar
Starting in 2000 or 2001 Jeep switched to a reverse rotation water pump and there are warnings blasted all over the FSM from those years about making double and triple sure you install a reverse rotation water pump for those engines. They claim that reverse rotation pumps are stamped with a "reverse" or "R".
It has to do with how they routed the serpentine belt on the later years. The engine fans for those years are also reverse rotation, too.
I was concerned about this because when I got my replacement pump the pump wasn't stamped with an "R" or anything. Yet when I finally took off the OEM water pump they were identical. And after reassembly everything is in good order with the engine temps right where they should be.
THAT SAID. . .
If your new pump matches the shape and direction of the fins of your OEM pump then I'd say you are in good shape. Go for it.
- Jay
lupinsea is offline
post #8 of 10 Old 03-03-2010, 05:33 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
THAT SAID. . .
The pre 2000 water pump won't properly bolt up to the 2000 and newer 4.0L. Nor will the fan clutch even come close to mounting on the water pump...
Knuckelhead is offline
post #9 of 10 Old 03-03-2010, 06:16 PM
tangofox007
Im 100% sure that it wouldnt stand for reverse. l
An "R" on a water pump impeller absolutely stands for reverse rotation. (Which is not to say that all reverse rotation impellers are so marked.)
Starting in 2000 or 2001 Jeep switched to a reverse rotation water pump...
Jeeps have been equipped with reverse rotation water pumps since way before 2000.
tangofox007 is offline
post #10 of 10 Old 03-03-2010, 06:18 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Stamped with an "R" or not, you can tell them apart by the shape/direction of the impeller. I put this thread together with pics a while back.
http://www.jeepforum.com/forum/f12/w...torial-893428/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
"clunk" with moving forward or reverse narleycarley TJ Wrangler Technical Forum 15 10-30-2009 03:12 PM
Water Pump: Forward or Reverse Flow? zener6 TJ Wrangler Technical Forum 3 04-02-2009 10:18 PM
4.0 Water pump rotation ChevDog1 YJ Wrangler Technical Forum 4 12-15-2008 01:31 PM
reverse rotation water pump and hi-flow ?? jbolty YJ Wrangler Technical Forum 5 08-03-2007 02:44 PM
New water pump and "stat" now it gets HOT JohnW63 YJ Wrangler Technical Forum 15 11-04-2004 03:27 PM
