Water Proofing My TJ - JeepForum.com
post #1 of 16 Old 08-06-2007, 03:46 AM Thread Starter
Ramland Jeeper
Hey Everyone,
I have researched, researched, and researched about water proofing TJs. I have a 1997 Sport TJ Manual. I would like to know what people have done to waterproof their rigs. This is what I have read.
-I have read that TJs before 2003 have vents on their trannys to vent.
-I read that you need to run breather tubes from both Diffs
-Dielectric grease on every electrical connection
-Also to make a vent for a gas tank fuel line since when you go into the cold water the warm tank creates a vacuum and it will suck water in the tank.
-Water proofing electronics
-Sealing the distributor
-Do something with the fuse boxs
-Covering the alternator
-Do something with the exhaust
(Now I just need to know what I’m missing and also what all this means)
I get some of this but I would love to get some write ups and so advise on how to make my Jeep as water-resistant as possible. NOW for everyone that is going to say "Why don't you just buy a sub" I don't want a U-Boat just peace of mind when I drive to work after a weekend of Wet Wheelin. I know there is no way to be 100% protected expet absonece, haha, but I want to be well prepared.
Some questions I have:
-Wouldn’t water contacting the battery short it out??
-When the cooling fan hits water will it put to much stress on it?
Also, I know once you do take your TJ into the water, you need to do some stuff to it after to keep it running and looking nice. Like regressing and changing fluids. But exactly what, where, and when should I do maintenance afterwards?
My jeep is a daily driver and my trail toy. I bought a snorkel cause if I hydro lock my Jeep I would not have a car to drive anywhere. I plan on taking my carpet out and eventually lining the tube. I take my jeep through a lot of wet trails and when I finish all this prep work I plan on taking in deep waters, up to hood levels at times.
Id love some Pics too!!!
Ramland Jeeper is offline
post #2 of 16 Old 08-06-2007, 04:25 AM
jeeptillidie
jeeptillidie's Avatar
I will add axle tube seals help to prevent getting water and mud in them.
jeeptillidie is offline
post #3 of 16 Old 08-06-2007, 05:07 AM Thread Starter
Ramland Jeeper
What exactly are those?
post #4 of 16 Old 08-06-2007, 05:09 AM
fromme
fromme's Avatar
Leave your Jeep on the land and get one of these for the water:
http://gvhighlights.blogspot.com/200...r-carboat.html
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #5 of 16 Old 08-06-2007, 05:22 AM Thread Starter
Ramland Jeeper
HAHAHA Yeah well I got a boat, Searay 175. But I like the TJ more, besides all TJs are Amphibious not to mention able to crawl over rocks.
post #6 of 16 Old 08-06-2007, 05:25 AM Thread Starter
Ramland Jeeper
Though I have thought how much mod I would have to do to get my boat able to go on the Road. I wonder if there is a Quadratec for boats.
post #7 of 16 Old 08-06-2007, 07:43 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You're right on track and it sounds like the search turned up some good info.
Put dielectric grease in all the electric connections and plugs. If you want to go one step further, cover them with liquid electrical tape. Just be sure to put a small wire under it (a twist tie works well) so you can remove the coating someday if necessary.
A bead of silicone under the cap helps a lot. It also helps to get a distributor cover from a Ford Mustang. Its just a rubber/vinyl boot that goes over the cap and acts as a splash guard.
Your diffs already have breathers that are pretty high. The front goes to the top of the radiator and the rear goes up near the gas filler. Check them out but they are probably already high enough for you.
I'm not sure about your t-case. I know on a 97 auto, the t-case vent is attached to the top of the bellhousing. Check where it runs on your manual. Just follow the hose from the driver side of the t-case.
Wheelin98TJ is online now
post #8 of 16 Old 08-06-2007, 09:13 AM
KI4KWF
nope, get one of these-
KI4KWF is offline
post #9 of 16 Old 08-06-2007, 02:07 PM Thread Starter
Ramland Jeeper
Okay Keep them comming...please
post #10 of 16 Old 08-06-2007, 03:36 PM
jappe
I have little over pressure in my axles. I use it in water, swamp and mudding.
Just do it
jappe is offline
post #11 of 16 Old 08-06-2007, 04:46 PM
opiv
opiv's Avatar
or this:
Get me my tools and beer.
opiv is offline
post #12 of 16 Old 08-06-2007, 08:30 PM Thread Starter
Ramland Jeeper
Okay Okay, I get it. BUT I would still like some serious responces with pics or write ups. Thanks
post #13 of 16 Old 08-06-2007, 10:06 PM
opiv
opiv's Avatar
See the link for the Daless2 writeup that Oman posted here...
http://www.jeepforum.com/forum/f9/deepwater-crossing-159286/
opiv is offline
post #14 of 16 Old 08-07-2007, 10:02 AM
Scafone
Scafone's Avatar
I routed the vent lines for my trans and t-case inside the cab, just under my manual shifter boot. I can just pull off the breather caps and actually refill both from the captains chair (I usually refill most of the way, then top off underneath where I can see the level). I first posted this several years ago here, but received mixed reviews. I am still happy with this setup and would do it again. Very little chance of getting any fluids in that way and I didn't need any extra hose....the t-case hose is long enough to use for both since it's a short run. I did buy another breather cap from the dealer though for the other line.
"Laws that forbid the carrying of arms...disarm only those who are neither inclined nor determined to commit crimes...Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man."
--Thomas Jefferson
Scafone is offline
post #15 of 16 Old 08-07-2007, 12:17 PM
03Wrangler
03Wrangler's Avatar
2010
electric fan with a switch to turn it off in the water... take the stock fan out..
heard this helps
03Wrangler is offline
Water Proofing the Engine? MeatPuppet YJ Wrangler Technical Forum 5 11-03-2006 08:39 AM
Water Proofing somaj TJ Wrangler Technical Forum 4 12-20-2005 02:36 PM
Water Proofing? Coppertone82 TJ Wrangler Technical Forum 5 11-29-2005 08:25 PM
Water Proofing ?s Savage4x4 TJ Wrangler Technical Forum 3 10-23-2003 06:19 PM
Water Proofing my YJ LI93RedYJ YJ Wrangler Technical Forum 6 06-07-2002 09:24 AM
