Water Proofing - JeepForum.com
post #1 of 5 Old 12-20-2005, 01:01 PM Thread Starter
somaj
Water Proofing
Anyone have any good links to water proofing steps for my TJ. I hit a pretty deep hole while on the trail and stalled it out. She would'nt start for almost a whole day. Everything is fine now. I want to take some steps to keep this from happening again other than using my head and avoiding suspicious looking water.
thanks
somaj is offline
post #2 of 5 Old 12-20-2005, 01:06 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
do a search for water 'proofing' as for the stall that was water in you distributor, dry it out and it will start, i learned to hard way to stay out of deep mud puddles, my last trip in one cost me a clutch, front brakes, new belt, both pinion seals, raditor, and all new fluids, and a tow home (hour and a half trip)
RnEmOvr is offline
post #3 of 5 Old 12-20-2005, 01:14 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
To keep water from getting under the cap, run a bead of silicone under it. Do NOT seal the vent that is on top. Extend it with a breather hose.
The biggest problem with water is that it ruins sensors. It helps to put dielectric (sp?) grease in connections, but it will not prevent problems entirely. I've heard of some people using liquid elec tape to waterproof even more, but I've never done it myself.
Wheelin98TJ is online now
post #4 of 5 Old 12-20-2005, 01:20 PM
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
From CanukYJ in a post to me many years ago
Water on the coil or distributor will short out the connections and cause the engine to bog, stall, or misfire. Open the distributor cap and try sealing it with soft gasket maker and spray a bit of wd 40 inside to displace any water in there. Get some silicone sealeant (sold as ‘engine electrical sealer’ at most autostores) and spray the hell outta the coil, distributor and plug wires. Those are the prime points of shorting other than the computer (which should be sealed already).
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline
post #5 of 5 Old 12-20-2005, 02:36 PM
emcee5000
emcee5000's Avatar
I have waterproofed the tranny (nv3550) and tcase and left the stock diff breathers alone. I have had water/muddy muck to the rockers many times and the Jeep sees 90 miles a day without incident from the trail to the highway. The best thing to do is not hit large or even semi deep pudles at high rates of speed (even though it is fun). It puts water in places it does not belong. Take it slow and steady and all of your intakes and seals will thank you.
emcee5000 is online now
Water Proofing My TJ Ramland Jeeper TJ Wrangler Technical Forum 15 08-07-2007 02:05 PM
Water Proofing the Engine? MeatPuppet YJ Wrangler Technical Forum 5 11-03-2006 08:39 AM
Water Proofing? Coppertone82 TJ Wrangler Technical Forum 5 11-29-2005 08:25 PM
Water Proofing ?s Savage4x4 TJ Wrangler Technical Forum 3 10-23-2003 06:19 PM
Water Proofing my YJ LI93RedYJ YJ Wrangler Technical Forum 6 06-07-2002 09:24 AM
