Quantcast water in passenger floor - help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > water in passenger floor - help!
Old 09-23-2006, 08:20 PM   #1
dsteiden
today i found water in the passenger floorboard. i remember having seen this listed as a problem with the a/c on 1997- 2003 tj's, requiring an extension on the condensation drain tube. somewhere i found a write up for doing this, but it has been months since then. i need to fix this soon, so any info would be appreciated. i drive a 98. thanks guys!
dsteiden is offline   Reply With Quote
Old 09-23-2006, 08:25 PM   #2
Rocky529
Jeep
Rocky529's Avatar
http://www.jeepforum.com/forum/f9/ac-drain-tube-fix-simple-292382/?highlight=drain+tube
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is online now   Reply With Quote
Old 09-23-2006, 09:02 PM   #3
tcestes
It's not always the AC. I read awhile back where someone removed their cowl on the outside, and took silicone and sealed all the spot welds, and it fixed theirs. Mine isn't AC related, cause i havent ran mine in weeks, yet after the last rain I got a lot in my passenger floorboard too.
2002 Red TJ
2" Budget Boost | 1" Performance Accessories Body Lift | LoD Heavy Duty Rear Bumper | LoD Rocker Guards w/steps | 33 x 12.50 Mickey Thompson MTZ's | Cragar Soft 8's with 4" BS| Flowmaster Exhaust
tcestes is offline   Reply With Quote
Old 09-23-2006, 09:54 PM   #4
dsteiden
any additional info on this mod? i may do both.
Old 09-23-2006, 10:17 PM   #5
jenders
check behind the battery
My TJ (which I sold ) leaked around the blower motor foam seal behind the battery. After removing the battery I resealed all around the foam with silicone and it took care of the problem. The way you can tell if it's leaking there is to take a flashlight and look inside at that area you'll see water streaks inside where the water ran down. Sorry no photos because I just sold my TJ for a Grand Cherokee. Hope you find the problem mine never leaked after I sealed it. Good luck.
[B]2004 Grand Cherokee Special Edition[/B]
jenders is offline   Reply With Quote
Old 09-23-2006, 10:49 PM   #6
dsteiden
wow. that's three possible causes? i guess i could check on that one too. any other reasons this could be happening?
Old 09-24-2006, 12:43 AM   #7
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Remove the hood cowl and seal around the vent box and every spot weld or crack you can see.I sealed mine with clear silicone and missed one small spot weld and got an inch of water on the floor.I fixed it in 15 minutes and now I'm dry. Seal everything!
TheBoogieman is offline   Reply With Quote
Old 09-24-2006, 02:06 AM   #8
14psisupra
pull the plugs
14psisupra is offline   Reply With Quote
Old 09-24-2006, 02:59 PM   #9
dsteiden
Originally Posted by 14psisupra
pull the plugs
that won't keep the carpet dry
Old 09-24-2006, 03:20 PM   #10
Grubbi
Carpet in a Wrangler?? Surely you jest.
'99 TJ 4.0, 3" Rusty's Lift, 1" Tera Body Lift, 33"s on Cragar Soft 8's
Warn XD9000i
My Jeep
Terrain Stompers Jeep Club Cincinnati, Ohio
Grubbi is offline   Reply With Quote
Old 09-24-2006, 03:24 PM   #11
dsteiden
just 'til i can afford line-x!
Glock Forum
