Water leaking in around doors and tailgate? - JeepForum.com
post #1 of 6 Old 12-07-2013, 01:55 PM Thread Starter
TJJeepJosh
about a week ago I went out to my jeep the morning after a big storm and noticed ice frozen in the rear foot wells and under the front floor mats. Figured I left a door open slightly during the storm so I ignored it. Now we have had 2-3 more storms and every time I go out its like a lake in every foot well.
Sat inside with a flashlight while someone sprayed a hose around the edges of the doors/hard top/tub and found water leaking in these places. No pictures of my jeep but these are the areas.
I know there is other threads on this but I couldn't find any that had actual solutions. I've tried adding some foam/gaskets in there but it doesn't seem to help much. any ideas?
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 6 Old 12-07-2013, 02:27 PM
gmtech22
It's leaking in the rear because there are gaps where the window meets the top. I wouldn't worry about the rear areas because running water over it with a water hose puts more water on it at one time than would be naturally possible. You need to have a nozzle at the end of the water hose that will spray water in droplets. My TJ will leak at the mucket seals when I ran water over it with a water hose but it won't leak in the rain. I had a leak at the seams in the rear where the seam tape was separating.
gmtech22 is offline
post #3 of 6 Old 12-07-2013, 02:48 PM Thread Starter
TJJeepJosh
The hose wasn't sprayed directly on the spot. Was sprayed over the area on a shower setting. Little droplets around the door areas but the rear was coming in pretty steady. I'm wondering if the rubber that the back window rests on is not fully attached at the bottom and as the water runs down the channel around the window if it collects and comes in there.
post #4 of 6 Old 12-07-2013, 03:19 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
In those areas you posted on the front doors, I would say new door weather stripping is in order. I would also check the front drain hose under the hood cowl (could be plugged)? In the rear its basically the rubber weather stripping on the hardtop that the glass meets when closed and the rubber weather strip secured to the bottom of rear window.Good luck!
GOLENJEEPTJ is offline
post #5 of 6 Old 12-07-2013, 04:04 PM
bobjp
As mentioned above, the typical leak is under the cowl, and it will fill your floor boards. You should consider checking that out too.
97 TJ sport.
bobjp is online now
post #6 of 6 Old 12-07-2013, 04:26 PM Thread Starter
TJJeepJosh
Seemed to be coming in more towards the back area so I have put aside checking under the cowl. might as well just to make sure though. Looks like a lot of new weathering stripping all around is needed..
help needed , seal leak , water leaking inside
