water leak - JeepForum.com
post #1 of 19 Old 11-28-2005, 05:29 PM Thread Starter
jonsjeepthing
water leak
has anyone had water leak in on the passenger side floor. its on both front and back on the passenger side. i sealed the area on the fire wall behind the battery, but still leaks!
jonsjeepthing is offline
post #2 of 19 Old 11-28-2005, 05:52 PM
jeffjeep1
jeffjeep1's Avatar
If you search you will find a lot of info. Mine leaked where the AC drain penetrstes the bulkhead (firewall). I put a 8" long hose over the tube in the engine compartment and let it hang. No more water inside.
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #3 of 19 Old 11-28-2005, 06:12 PM Thread Starter
jonsjeepthing
i have no ac tho. i did see water come out from by the roll bar on the back passenger floor, when my friend shook the jeep.
post #4 of 19 Old 11-28-2005, 06:24 PM
fundabug
fundabug's Avatar
I have a 2004 TJ and I've been tracking leaks since I got it. For every leak I fix another one shows up. I still have not stopped the leak behind the passenger seat, but I have found some leaks around the passenger door that may be suspect...anyway...good luck and welcome to the world of Jeep leaks....It never seems to end!
fundabug is offline
post #5 of 19 Old 11-28-2005, 09:16 PM
The_'ster
I've had both the pass door leak and the behind the seat leak. The pass door leak is either a clogged/loose A/C drain, or the water is getting in between the front of the door seal and drips off the lip of the door opening. Could be a misaligned door or a poor fitted top. The leak behind the rear passenger seat is water getting through the seal at the bottom of the rear window and the top of the tailgate. I applied a peice of weatherstripping to the bottom of the window so the rain water drips off the strip instead of running down to the tailgate/window seal.
'98 TJ has been under the knife the last 30 months getting a new frame, torque boxes and fenders.
The_'ster is offline
post #6 of 19 Old 12-10-2005, 10:29 PM
SpoolinU
SpoolinU's Avatar
I have this problem as well....had almost 3 inches of water in my passenger side rear floor and fron passenger side as well...how the hell do you find these leaks to fix them
SpoolinU is offline
post #7 of 19 Old 04-05-2010, 05:27 PM
GoldenEagle21
I know this thread is about 4 1/2 years old, but I noticed on mine that the water was being pushed through a gap in the wheel well and inside the floor boards. It was making its way under the carpet through gaps around where the roll bar is bolted to the floor. I let all the water drain out and then sealed the hell out of it with GOOP and that helped a lot. I just need to get under the seat belt anchor to seal that up and that should take care of it.
GoldenEagle21 is offline
post #8 of 19 Old 04-06-2010, 02:02 AM
Jonny Jeep
Jonny Jeep's Avatar
Seems to me like you are just going to be trapping water behind the roll cage mounts. I had a leak in that area that I fixed. The rust had got under the paint so will still get in even with the goop. The leak was caused by the sticker over the hole behind the rear flair coming unstuck. Can't find my pics of the rust at the moment but the hole I write of backs directly on to the roll cage mounts.
Jonny Jeep is offline
post #9 of 19 Old 04-06-2010, 01:34 PM
GoldenEagle21
How'd you figure out it was coming from there? Maybe I'll try to take the flare off tomorrow and see if there's any holes. But to me, it seems that the water is only coming in after or while I drive. That's why I figured it was coming in through a gap behind the wheel well liner...
post #10 of 19 Old 04-06-2010, 01:55 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Try pulling the front cowl off in front of windshield and check for debris plugging.That's usually the first place to check.
GOLENJEEPTJ is offline
post #11 of 19 Old 04-06-2010, 02:16 PM
GoldenEagle21
Ya that was the problem in my last jeep. This water is coming into the backseat through the floor.
post #12 of 19 Old 04-06-2010, 04:25 PM
Jonny Jeep
Jonny Jeep's Avatar
I took months to find the leak. I only seemed to get water in the rear foot well after heavy rain and usually when the Jeep was parked on a slight downward slope.
I had a few minor leaks from the top and thought the water may have been coming in from them but I treated and sealed the top and got rid of all trace of water coming in from the top. I even got a chalk pen and marked all the way around the full door seal and was getting no leaks there. Even with the leaks I had in the soft top, I couldn't see how the volume of water I was getting could possibly be from those as I was only finding drips from them.
I saw a photo on this forum showing the hole behind the flare and figuring it was a possibility removed the front few bolts on the rear flare. Sure enough the sticker was not completely stuck down. I removed the old sticker and put some tape over the hole. Did the same on the other side too and not a drop more got into the rear foot wells.
With the leak sorted I pulled the roll cage and cleaned up the rust.
I noticed some bubbling paint further along from the rust on my passenger side, so cleaned up the paint till I was sure I was at the end of the rust.
The rust actually went quite far.
Painted over the area with POR15 including the roll bar bases, and top coated in the factory colour after that.
post #13 of 19 Old 04-06-2010, 05:58 PM
Flyboy161
I have a soft top and I collect water behind the passenger seat. What I saw one day was water dripping off the aft stiffener bar for the top. Apparently it migrates in through the stitched seam that runs across the back and runs down the bar to it's lowest point before it bends back up to the roll bar. From there it drips down to the wheel hump and seeps down to the passenger floor. I am going to treat the top with some 3M Scotch Guard.
I have also noticed the AC evaporator drain leak under the glove box near the center console! I just tell my wife to move her purse!
Owning a jeep is like raising a rebellious teenager: the more you love it and nurture it and buy nice things for it, the more it says, "screw you! I'm doing drugs and drinking because I hate you!"
Flyboy161 is offline
post #14 of 19 Old 04-06-2010, 05:59 PM
klincker
i got water because my cowl was gunked up in my old YJ.
2013 JKU Sport S 6speed
99 TJ sahara 5spd--sold
94 YJ 4cyl 5spd--sold
klincker is offline
post #15 of 19 Old 04-06-2010, 06:10 PM
panhandlejeep
Here is a link on ḧow to fix water leak.
http://www.jeepforum.com/forum/f9/tj...-fixed-893784/
panhandlejeep is offline
Water Leak (not the regular FRONT leak) jrs948 TJ Wrangler Technical Forum 1 01-18-2010 06:05 AM
95 YJ Radiator Leak/ Water Pump leak?? SThomas86 YJ Wrangler Technical Forum 11 01-05-2008 04:25 PM
Oil Leak..Water Leak...Comp. meltdown tbrkek JK Wrangler Technical Forum 30 10-07-2006 02:47 PM
water leak from somewhere hed11877 TJ Wrangler Technical Forum 2 11-28-2005 06:58 PM
water leak fezzik TJ Wrangler Technical Forum 5 02-12-2005 07:41 AM
