#1 | |
Water in Footwells but no rain ?!
Hi Folks.
I drove back to Atlanta, GA from Virginia yesterday and when I lifted my cooler from out the passenger's footwell i saw 3 inches of water in the front as well as in the back. But I didn't go through a creek on my way back, I swear... So where's that water from? I guess it might be from the A/C cause I had it going pretty good all the way back home. If this is the case, what causes the water to go, where it don't belong and what can I do about it? Is there a drain in the A/C that might be clogged up? Thanks ya'all...
Save a tree, hit a rock! '99 Wrangler TJ yellow, 4L R6, 33" Laredos on black steelies, 4.5" lift |
#2 |
First thing, are you sure your cooler wasn't leaking?
[SIZE="1"][B]98 TJ-bought-not built [url]www.PNWJeep.com[/url] كافر - Infidel[/B][/SIZE] |
#3 | |
I wave.. do you?? No Jeep No Trail!! There's just something about a Jeep that puts a smile on my face, and my passengers!! |
#4 |
x3 on the cooler... see if it does it with the cooler removed
FOR SALE Olympic Trunk for 03 TJ |
#5 | |
Junior Member
3 inches from the AC condensation would be normal, considering he drove from ATLANTA to VIRGINIA ![]() OP, here's the answer to your problem http://stu-offroad.com/body/ac/acleak-1.htm |
#6 |
I did Stu's write up on the link above and my water problems were taken care of. Very cheap fix little over a buck.
#7 | |
So what you explain on your website sounds really like an easy fix. I will get right on it tomorrow, cause I am going back to virginia on monday and I don't wanna experience that again... Thanks a lot... ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
