#1 | |
Mechanically Declined
Warrior Safari Rack
I'm looking into getting the Safari rack from Warrior Products. Was wondering if anyone has had problems with the support bars being on the side of the jeep like that? Does it sway much and bang the side of a hard top? I've seen some people complain about snagging trees and such.
The price for the Safari is about quite a bit less than the Garvin and Kargo systems, though I'm not too keen on drilling into the side of the tub. Anyone thats had experience with this product, I'd sure like some feedback. Like wind noise, stability, and hight from top of jeep to bottom of rack. Hows the powder coat? I've seen one review that said it was lacking. Where's the cheapest place that you've found that Warrior rack? Any input is greatly appriciated.
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack. "When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do". www.despair.com |_ |T| |
#2 |
Fish fear me
I haven't had any problems with mine. The supports really don't stick out that far. My fender flares are much wider than my rack supports. As long as you keep the load within it's rating side to side movement is minimal. The powder coating isn't bad, mine chipped off a bit around the axe mount because I tightened it pretty tight and actually bent the metal. Mines nearly 3 years old (42,000k) and still looks good IMO. I have had problems with mud and rocks getting wedged between the hard top and the support rails and rubbing a little but who gives a rip about paint, right.
2003 Lt. Khaki Rubicon automatic Supercharged 4.7 stroker w/ Hesco aluminum head 70mm F&B throttle body Kieth Black forged 944 pistons Comp Cams custom ground camshaft 505 Performance PCM Split Second Engineering fuel/timing management Tom Woods CV driveshaft 50 lb/hr Trick Flow injectors 4" Full Traction LA with Bilstein 7100's JKS 1" MM,BL. TeraFlex engine and steering armor 4.88's w/ 35 " Toyo Open Country m/t's Moser Chromoly axle shafts front, Superior D44 rear Warn 9.5ti on a M.O.R.E hi clearance bumper Reid racing knuckles, Warn premium hubs PIAA 525's, and 510's XBOX Gamertag- ISHAGDyurGURL For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30 |
#3 |
Righteous! Thats the best picture of the rear mounts I've come across. Thanks a bunch.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
