Quantcast Warrior Adventure Rack 834 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Warrior Adventure Rack 834
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 07-21-2006, 03:59 PM   #1
towerassoc
Location: Prescott,AZ Summer, Sun City West, AZ winter., AZ
I'm trying to find away to install gas cans and found the Warrior Rack. Has any one used this rack and I don't understand how it mounts.?
Thanks
Bill
2006 Rubicon.
towerassoc is offline   Reply With Quote
Old 11-20-2007, 10:48 AM   #2
FooK
It mounts through the tailgate. Each leg is drilled through the tailgate in two spots, and bolts through it. You are only drilling the tailgate, the holes are already pre-drilled in the rack.
Additionally, there is a mount plate that you install onto the area of body under the tailgate (commonly referred to as the backplate) that has a quick pull pin that goes through the leg. This is held onto the blackplate with 4 screws each.
We've had very good luck with these racks and in the 3 years I've been here I have only seen one fail, and that was due to someone not building the legs out of the proper wall thickness square tube. If something like that ever happens the company has always been good about replacing defects like that no questions asked.
Hope that helps.
2002 WJ Limited 4.7L Quadradrive
Built to serve rally racing in communications, crash recovery and medical response.
My exhaust clip http://www.youtube.com/watch?v=M_8aTOEbRrc
FooK is offline   Reply With Quote
Old 01-26-2010, 12:14 AM   #3
ratfink4545
how does the mount plate install and what does it do?
everything looks better through a plastic window
ratfink4545 is offline   Reply With Quote
Old 01-26-2010, 09:15 AM   #4
FooK
It screws into the body under the tailgate and gives the legs one more attachment point other than that two in the tailgate...just makes it that much stronger.
Glock Forum
