warn manual hubs for tj - JeepForum.com
post #1 of 26 Old 05-05-2013, 11:46 AM Thread Starter
jwhite727
im looking to replace my warn manual hub but i cant find anything for them. I asked if other 5x4.5 hubs would work and the sales guy said no is that true? i have a dana 30 with 27 spline count. if you know where i can locate some it would be greatly appreciated.
jwhite727 is offline
post #2 of 26 Old 05-05-2013, 11:50 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
www.ringpinion.com. Randy's Ring & Pinion is who bought the Warn line of manual hubs, though you may get frustrated trying to find someone at Randy's who knows much about them. If you can figure out the Warn part numbers you need, you may have better luck finding them on the internet like via Google's shopping website at www.froogle.com.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #3 of 26 Old 05-05-2013, 06:24 PM
Kiwi
Are you just looking for one hub? If so I might be able to help you out.
Kiwi is offline
post #4 of 26 Old 05-06-2013, 07:32 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have been looking for a set far and wide with no luck. What are the part #s?
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #5 of 26 Old 05-06-2013, 07:46 AM
Kiwi
Here you go on part numbers, or are you looking for the whole hub conversion as a kit?
Kiwi is offline
post #6 of 26 Old 05-06-2013, 08:55 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not that they are the same strength, but the Ford Ranger hubs are the same.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #7 of 26 Old 05-06-2013, 11:13 AM
Andy-WhiteTJ
Last summer when I blew my hub, I called Randys and gave them the number for the hub (37780). They had it in stock and shipped it out the same day. I did have to purchase the hubs in pairs.
The whole kit may be another story...
1998 White TJ with a whole lotta stuff...
Just another member of:
(a 501(c)(7) Not-for-Profit Corporation)
Member:
(Northeast Off-road Vehicle Alliance)
Andy-WhiteTJ is offline
post #8 of 26 Old 05-06-2013, 03:51 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Personally, I was looking for a hole kit. Should I call Randy's or someone else?
16 Taco
dayriesw is offline
post #9 of 26 Old 05-07-2013, 12:08 AM
Jerry Bransford
Administrator
Randy's is who I would call first for the entire hub kit.
Getting
post #10 of 26 Old 05-08-2013, 09:10 AM Thread Starter
jwhite727
i bought part number 37780 from amazon for 204 and it fit like a glove . . . thanks for the help. I've been looking for that part number for some time. It came in a pair since i didnt need the whole kit since my spindle washer and axle retainer were the only things broken.
post #11 of 26 Old 05-08-2013, 09:13 AM
Kiwi
I don't understand why you needed to buy the hub if you only needed the spindle washer and axle retainer? You can get those parts separately.
Kiwi is offline
post #12 of 26 Old 05-08-2013, 09:16 AM
Jerry Bransford
Administrator
Carrying a spare hub for that particular (aka "small") hub is a good idea, it can be swapped in seconds if it breaks while offroading. I did when I ran the small Warn hubs as that model # is.
Getting
post #13 of 26 Old 05-08-2013, 05:03 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Is there a big hub that can be swapped into this setup if that's the weak link?
16 Taco
dayriesw is offline
post #14 of 26 Old 05-08-2013, 05:14 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Trust me, you won't want to. I developed a steel body hub with a drive flange and never turned it into a product when testing showed the carnage it can cause.
I'd never seen broken small hub kit stub shafts until we installed that kit on several rigs. I think out of 5 kits I sent out and or installed, all but one killed stub shafts and spindles.
Let the hub break, it's worth it.
I am Savvy
post #15 of 26 Old 05-08-2013, 07:50 PM
Kiwi
Yes, it is good at creating carnage to hard to find replacement parts.
Broken stub shaft
Trail repair with bailing wire and JB Weld
Destroyed spindle
Destroyed spindle nuts and spindle washer
Kiwi is offline
dana 30 , jeep wrangler
