Want your opinion on my bumper build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Want your opinion on my bumper build
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 12-14-2013, 06:53 PM   #1
Bobby6319
(Update)Want your opinion on my bumper build
I am building bumpers for my jeep and was wondering if it is to wide. It is 59" wide now I haven't boxed the ends yet so I can still shorten it. Do you think I should put a loop on top or maybe a stinger?
Bobby6319 is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 09:25 PM   #2
badmoose
Personally, I think it is too wide. But it is your Jeep. I would cut it off at the mid point of the slant cut.
2005 TJ
Zone 3" suspension lift
General Grabber AT2's 33x12.5x15
badmoose is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 09:35 PM   #3
Moezer
2015 JK Wrangler
I say add a stinger and keep it the way it is, if you don't do a lot of rock crawling then u don't have to worry about it, think about it this way if u crash in to some one from the side of the jeep there is a good chance you can still minimize the damage to the axle or even your hood and side fenders
Moezer is online now   Reply With Quote Quick reply to this message
Unread 12-14-2013, 09:52 PM   #4
JPGoody
U can build your own bumper!?! You're like a snail, rock on. Go with what you like. Looks wise, I'd go narrower, but only you know it's function.
If I had said building skill I'd mount one of those pedal bike front fork lock pin things and some rod holders and I'd def weld in a bottle opener and maybe even a beer can sized depression/reservoir on one end.
JPGoody is offline   Reply With Quote Quick reply to this message
Unread 12-14-2013, 09:56 PM   #5
Spud100
Maybe 3" off each end. Nice workmanship. It really looks true and straight.
Spud100 is offline   Reply With Quote Quick reply to this message
Unread 12-15-2013, 01:36 PM   #6
pierps
Nice looking craftsmanship!
Are you primarily concerned about aesthetics, or function?
If aesthetics, my opinion is that it's not necessarily too long, but it's too long in proportion to its thickness (on the vertical plane). So if you were starting over, I would suggest going with a wider tube as your starting point if you want this length. Otherwise, I agree with some others- take 3" or so off of it. The tough thing is determining where to cut it off. It looks most natural if it matches a major feature of the body, such as the fenders or edge of the grille.
If function, then it depends on your expected use. As another poster mentioned, if you want to do some rockcrawling, then a long bumper might get in the way. If it's mostly on the road with no rock crawling, then this is a good length.
pierps is offline   Reply With Quote Quick reply to this message
Unread 12-15-2013, 07:42 PM   #7
Bobby6319
Ok cut 3"s off each side d rings welded on and a bull bar just need light tabs and ready for paint and then start the back with swing out tire carrier . Oh my winch should be here tomorrow
Unread 12-15-2013, 09:01 PM   #8
LukeADukes
Looks nice
Always look both ways before crossing the stream.
LukeADukes is offline   Reply With Quote Quick reply to this message
Unread 12-15-2013, 10:37 PM   #9
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by Bobby6319 View Post
Ok cut 3"s off each side d rings welded on...
Are those D-ring holder brackets surface welded onto the surface of your bumper as they appear to be? If so, they would be way too dangerous to use, I would remove them. Such holders need to be held by a tab passing through the bumper and through-welded on both sides to be strong enough and safe enough for vehicle recoveries. Surface mounted D-ring holders are dangerous enough that I wouldn't leave them on even for looks. Someone could be seriously hurt by using one in an emergency, like if you were too incapacitated to warn against their use if you just left them as is.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 12:28 AM   #10
freeskier93
Lots of manufacturers use surface mount tabs or d-rings. Gen-right comes to mind, those things are usually rated to 5+ tons. I picked some up on Amazon that are 20 tons, haven't gotten around to welding them on to my Gen-right crossmember.
Build Thread
My life in 2010: Chronicles of painting my Jeep
Axle Re Gear and Swap
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 12:41 AM   #11
rubidriver
Heres a thought, rotate your pics if you want feedback. I would not use surface mounted rings. I would use clevis mounts that are welded on both sides of the square tubing. Winching can be very dangerous with those.
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 01:12 AM   #12
TJdualsport
Add gussets to the bar. Connecting the bar to the bumper.
my dual sport build http://www.jeepforum.com/forum/f22/project-bumptastic-947070/
TJdualsport is offline   Reply With Quote Quick reply to this message
Unread 12-16-2013, 01:12 AM   #13
TJdualsport
Ooo oooo. And some light tabs lol
Unread 12-17-2013, 01:53 AM   #14
Moezer
2015 JK Wrangler
BIGGER STINGER!!! make it as high as the hood
some thing along the lines as mine maybe?
Unread 12-17-2013, 10:11 AM   #15
Leffnasty
Originally Posted by Moezer
Did you make yours or is it from a company? I've been wanting to make one similar to yours or the OP but I simply don't have the means in college. I don't mean to hijack here, both of these bumpers are awesome and I give you props to making it so well OP
Leffnasty is offline   Reply With Quote Quick reply to this message
