Want to run 32x11.50x15 What size Lift? - JeepForum.com
post #1 of 52 Old 02-01-2007, 05:48 AM Thread Starter
NDClown
NDClown's Avatar
I currently own a 2000 Sahara and want to be able to put on 32's. Do I need a lift? If so how much do I need to lift it? I probably just want to do a suspension lift if possible. And what would the cost be on average? Thanks a lot
2000 Jeep Wrangler Sahara, 4.0L, Full Traction 3" lift. Old Man Emu shocks, Garvin Top Rack.
Black Dck Cepek DC-1's
Dck Cepek F-C II's 33X12.50
Full Traction Steering Stabalizer
AtoZ Fabrication Rocker Guards
Aussie Front Locker
NDClown is offline
post #2 of 52 Old 02-01-2007, 05:53 AM
wahooz04jeep
You need to at least do a 2" BB. It will give you the clearance. Different opinions tell you whether or not it will work comfortably or not. some will also suggest a 1" BL with it also. I'm planning on 2" BB with 33's. maybe a 1" BL also. Any kit you can find online if you get the right shocks with will give you the lift you want.
2007 Jeep Patriot Sport
OlllllllO
I wave
wahooz04jeep is offline
post #3 of 52 Old 02-01-2007, 05:56 AM
Srhmn8r
Yea a 2" Budget Booster or "spacer lift" will do the job for you. You can pick up a kit for about $220 inluding shocks, or slightly more if you upgrade to premium shocks.
03 Rubicon RE 3.5" and 1.25" JKS BL 35" BFG MT's
Srhmn8r is offline
post #4 of 52 Old 02-01-2007, 06:00 AM
tmwoodall
Get the nicer shocks I am starting to wish I did. I just learned that my Es3000 are among the stiffest for jeeps. The BB will work fine for 32's that is what I Have. I wish I had done a 2.5" spring lift though.
tmwoodall is offline
post #5 of 52 Old 02-01-2007, 06:00 AM
wahooz04jeep
and if you want to go to the cheaper route, You can get the spacers on ebay for anywhere from 60.00 buck for just the spacers to 100 that comes with the BPE shock extenders and rear bumpstops.
OlllllllO
I wave
post #6 of 52 Old 02-01-2007, 06:52 AM
bigV
bigV's Avatar
I had a 1.75" daystar coil spacer lift that came with extended bumpstops and I used the stock shocks and had no problems clearing 32's. The kit was a little over $100.
bigV is offline
post #7 of 52 Old 02-01-2007, 07:03 AM
06rubicon
2017 JK Wrangler
Look into the OME lift, Its a nice way to go. Add a body lift later if the tires rub.
06rubicon is offline
post #8 of 52 Old 02-01-2007, 07:06 AM
Rule303
Do a 2.5" lift like the OME. Gives you another 3/4" over a typical BB. Should be enough to run 32s. I think someone saw the OME for around $500 at Northridge.
Rule303 is offline
post #9 of 52 Old 02-01-2007, 07:12 AM
shaggy105
No doubt that OME makes a great kit, but he MIGHT not want to blow $600 bucks (plus possibly paying someone to install it) to fit 32' tires... BB's are cheap and pretty easy to do yourself.
RED JEEP CLUB MEMBER 413
4.0L Auto
D Cepek DC-1 Rims w/ 33x12.5 Wrangler MT/R's w/ Kevlar
Rusty's front and rear bumpers
Poison spider rockers
shaggy105 is offline
post #10 of 52 Old 02-01-2007, 07:30 AM
Xlr8n
1986 TJ Wrangler
If the Jeep is also a DD, keep in mind the higher lift you go with the stock control arms, the rougher the ride will be. I'd lift enough to get good clearance with 32's but no more than necessary. You have to find a happy medium between clearance/looking cool and keeping a lower center of gravity/good road manners. One offsets the other unless you go to a longarm kit which will ride better than a 3" or higher short arm kit.
Xlr8n is offline
post #11 of 52 Old 02-01-2007, 07:51 AM Thread Starter
NDClown
NDClown's Avatar
Thanks I really appreciate it.
Aussie Front Locker
NDClown is offline
post #12 of 52 Old 02-01-2007, 08:25 AM
mferrari
DelmarvaOffroad.com
mferrari's Avatar
I was in your boat...
1.75" Spacers (w/ stock shocks) --- Rubbed when disconnected
1.75" Spacers w/ 1" BL --- No rubbing issues (sorry not the best pic, but only ran this setup for about a month)
Current Lift (See sig) --- Amazing package! Upgrading to 33s shortly...
PM me if you have any questions
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline
post #13 of 52 Old 02-01-2007, 09:36 AM
wahooz04jeep
How do you feel about the 32's. I would like to have 33's but it's a DD and am not planning on more than the BB and shocks.
OlllllllO
I wave
post #14 of 52 Old 02-01-2007, 09:46 AM
mdm
Farm Wheeler
If you disconnect the anti-sway bar your tires will most likely try to eat your fenders with just a 2" BB. Add a 1 to 1-1/4 inch BL and you should be OK.
mdm is offline
post #15 of 52 Old 02-01-2007, 09:51 AM
bigV
bigV's Avatar
with the extended bumpstops my 32's didn't rub when flexed & disco'd
bigV is offline
Who has DONE 32x11.50x15 on a STOCK Jeep? Shawn w TJ Wrangler Technical Forum 6 05-12-2009 12:53 PM
Actual tire size for 32x11.5? 4bangerWrangler TJ Wrangler Technical Forum 5 05-12-2008 03:15 PM
4 in lift and 33x12.50x15 apexjeepinjoe TJ Wrangler Technical Forum 9 10-16-2006 09:32 AM
What kind of 32x11.50x15 Dctjwrangler01 TJ Wrangler Technical Forum 5 06-07-2004 08:44 PM
32x11.50 and 1" body lift, no lift kit ageep TJ Wrangler Technical Forum 3 04-10-2003 08:32 PM
