Want lift 2006 Wrangler Rubicon Unlimited 2" to 2.5". Need lift system advice.
#1 | |
Want to lift 2006 Wrangler Rubicon Unlimited 2" to 2.5". Need lift system advice.
I want to lift my 2006 Wrangler Rubicon Unlimited 2" to 2.5". I'm not staying low because of money reasons. I'm staying low because I want good safety and handling both on and off road with 33" tires. I fully expect to do some fender trimming. Actually, I plan to install the American Expeditionary Vehicles Highline Body Kit, and maybe also do some fender trimming. Being lifted 2" to 3" would be plenty of height for my 33" tires.
I'd prefer to keep the lift from 2" to 2.5" if possible. I also want a good comfortable ride and good articulation off road with sway bar disconnected. I'd need to keep my daily driver (only vehicle) dependable and reliable. So I don't want to be prone to breakdowns. I've been looking at Rancho, Skyjacker, ARB, Teraflex, BDS, and Rubicon Express. I want the best performing 2" to 2.5" lift I can get. I don' t mind paying for it. However, I have little or no idea which one. I've been seriously considering using OME 2" Springs and Shocks with some other brand of 2.5" to 3" lift kit system that has more hardware parts/pieces to increase articulation. Is there a brand that sells one kit that does it all? I don't mind paying for OME springs and shocks and also paying for another brand of lift system and then combining them, or just buying and using one brand system only. Either way is fine if I can get a good result. Are heim joint control arms (short arm length) (available in some lift kits/systems) reliable? I've heard they are not reliable and give lots of problems. I've also heard they work great. I don't know. What about the ball joint type control arms? More reliable? Still give good flex? Advice would be appreciated. Thanks.
#2 |
you should look into the ultimate OME kit from dpgoffroad.com
http://www.dpgoffroad.com/TJ_LJ_OME_Kits.htm |
#3 |
I used ZJ front and LJ rear springs from OME. Very nice stable ride and smooth ride like stock, with a load still get a good three inches. I added about two inch of spacer to the bumpstops and clear 33x11.20-16 (285x75-16) Swamper TRXus MT.
#4 |
Understand that with only 2.5" of lift you're just not going to get a lot of articulation, especially with the bump stops necessary to prevent heavy rubbing. (You didn't say but I assume you are planning on 12.50" wide 33's) There's just not enough room for that size tire with that lift to tuck up into the fender and then drop away for the vehicle. That being said, for your situation I would recommend some 1.5" coil spacers, some quality aftermarket shocks, quick disconnects, a quality body lift (like the JKS 1.25") and a 1" mml. The latter 2 items would allow for a quality "high clearance" t/c skid, like 33 engineering's "high clearance" skid...
http://www.rockcrawler.com/techreports/33engineering_tcase_skid/index.asp This alone will give you an add'tl 2"-3" of ground clearance under your jeep. Amazing how many people lift there jeep only to lower the transfer case thus giving up the most valuable clearance. This set up will leave you with a reliable and very trail worthy rig. |
#5 |
I here the OME is a great lift for that size. If you go AEV highline then you probably won't need the trimming. Rokmen also make a highline kit now.
What Is A Veteran? A "Veteran" -- whether active duty, discharged, retired, or reserve -- is someone who, at one point in his life, wrote a blank check made payable to "The United States of America," for an amount of "up to, and including his life." That is honor, and there are way too many people in this country today, who no longer understand that fact. |
#6 |
Well, I'm sure I can easily fit my 33 X 11.3" Cooper Discoverer ST tires will fit very well with 2" or 2.5" lift and the American Expeditionary Vehicles Highline body kit. A Highline Body Kit allows the use of 33" tires with no lift, assuming correct wheel backspacing and an aftermarket front sway bar that offers more tire clearance.
So I should have no problems with 33" tires. With some rear fender trimming it'd even take 35" tires with only a 2" or 2.5" lift and Highline Body Kit. Highline Body Kit http://www.aev-conversions.com/products/highline/ I also plan on using an Nth Degree Tummy Tucker for my high clearance transfer case skid plate because it requires less vehicle modifications (no motor or body lift needed) than other high clearance transfer case skid plates. So yes, I do plan on raising T-Case and skid plate, not lowering it. Tummy Tucker high clearance (easier to install) transfer case skid plate. http://nthdegreemobility.com/catalog/product_info.php?products_id=29&osCsid=ffd0e223891 5e15faab27d2d0c444aae And a Skid Row Engine and Tranny skid plate. http://www.skidplates.com/engine_skid_plates_97_06_TJ.htm So all that said, I should have no problems using 33" X 11.3" tires with a 2" or 2.5" lift, considering the Highline Body Kit. Since I'd also gain gut clearance in the middle due to Tummy Tucker, I'll be 4" to 4.5" higher in the middle, but vehicle only being 2" to 2.5" higher. This with 33" tires, but it can also be done with 35" tires if some rear fender trimming done when installing the Highline Body kit. However, I still need to figure out the best way to lift it 2" to 2.5" and get a good ride, decent articulation, and a reliable install that won't break down - considering this is my only vehicle. Last edited by CB3; 04-19-2007 at 09:31 PM.. |
#7 |
CB- I am currently running 285/75-16's (33x11.50's) on stock Moab wheels with an OME 2.5" spring lift. For now I have the bumpstops extended where I get no rubbing and good articulation. I had the lift on with 32's and recently upgraded to 33's and had been plotting my next move which would either be a 1" spacer on top of the springs, or a 1.25 inch BL, but I'm liking the height so well, I may just leave it as-is. I have a current pic with the lift and new tires in my sig line.
#8 |
Looks good ^. Looks like mine actually. I have the same size tires that you do, but on stock wheels and stock Rubicon Unlimited 2006.
Bumpstops? You mean those rubber things the axle-frame hits when suspension bottoms out? You mean you extended those to prevent your tires rubbing your fenders when suspension compressed? Is that what you mean? |
#9 | |
I could actually take off my spidertrax wheel spacers and get the tires to stuff much further and increase travel, but I like the wide stance and stability they offer. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
