Quantcast Want to ditch the shovel w/ new t-case skid w/ minimal mods - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Want to ditch the shovel w/ new t-case skid w/ minimal mods
Old 07-10-2008, 08:29 PM   #1
xeneau
I've seen quite a bit of info on the belly up's and know the sye needed on many.
Does anyone have an angle on a shovel replacement that actually keeps the
t-case in place?
xeneau is offline   Reply With Quote
Old 07-11-2008, 03:23 AM   #2
rubiwannabe
i just got done doing mine and although i like the results. let me tell you its alot of work and not very cheap eaither....
rubiwannabe is offline   Reply With Quote
Old 07-11-2008, 07:25 AM   #3
UTWeezul
The EMP Skid only raises everything an inch. If you aren't running a t-case drop you could throw that in and everything would be the same as it is with the stock t-case skid...just a lot stronger. It is 1/4" steel.
http://www.extrememetalproducts.com/
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is offline   Reply With Quote
Old 07-11-2008, 07:29 AM   #4
Unlimited04
Unlimited04's Avatar
you cant really have a belly-up skid without a 1" BL + 1" MML, and a SYE if you have a lift. When you raise the t-case up 2.5", you need to raise the rest of the driveline, otherwise your output shaft will be pointing towards the moon, and the t-case, trans and engine have to have someplace to move too. If you have a 2" lift, then doing a 2.5" belly up is like having a 4.5" lift.
Unlimited04 is offline   Reply With Quote
Old 07-12-2008, 07:01 AM   #5
xeneau
Thanks for the insights everybody!
I opened up the hood and got down below and looked at things more closely.
In examining things more closely I can see how moving one end of the
system up could muck things up if the other didn't get some attention
as well. That comment "otherwise your output shaft will be pointing towards the moon" by Unlimited04 shifted my perspective. Once I actually looked
at it was sort of a revelation... "Unlimited04's got a point there."
Again, thanks. I'll just hire myself out as a road grader until I can put some
time and $'s into the shovel mod.
Old 07-12-2008, 10:44 AM   #6
FifteenCents
The SYE and the flat skid plate is really a great MOD.
I am kicking myself for not doing it sooner.
Trust me you'll love it.
It does involve a lot of stuff though. upper control arms, new driveshaft
rear track bar adapter, skid plate, SYE.
Everything seems to cost about 200 bucks each too.
The above post is my opinion and I have no facts to prove it... :)~
http://www.tjhardcore.com
The ultimate TJ owners only forum
FifteenCents is offline   Reply With Quote
Old 07-12-2008, 02:15 PM   #7
chutta
One of the best mods out there. Other than the stupid 40" tire mud pits, I don't get stuck anymore and look forward to logs to hop. Over 18" of clearance at the middle changes everything
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline   Reply With Quote
Old 07-12-2008, 02:56 PM   #8
Brown Dog
Vendor
Brown Dog's Avatar
When you look at MMLs, take a look at ours.
http://browndogindustries.com/2000-40L-Jeep-Wrangler-TJ.aspx
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Join our FaceBook group
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% MADE IN AMERICA
OFFROAD-REVIEW of Browndog Superkit
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" BFG Mud Terrains
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Glock Forum
