Want to convert from Hard Top to Soft Top-What do I Need - JeepForum.com
post #1 of 12 Old 07-26-2009, 03:48 PM Thread Starter
explorerlyon
explorerlyon's Avatar
I have a hard top on by 05 Unlimited. I want a soft top. After reading through all the fourms, looking at the Mopar (OEM) top, Viking, etc, I am a bit confused on what I need to make the conversion.
1. Windshield headder-Best I can determine is I need one
2. Door surrounds--Don't understand what these are and if I need them.
3. If I order a factory top from Jeep, does it include the headder, door surrounds, etc?
Thanks
explorerlyon is offline
post #2 of 12 Old 07-26-2009, 04:05 PM
Muddybrit
Do not need a header for any full soft tops only the bikini types. Door surrounds are plastic pieces that screw along the roll bar and down to the tub so that your doors can seal against something firm. 5 mins to fit. Several different types and brands of soft top, an OEM one is no doubt the best and can be found on craigslist etc and again under an hour to attach and then about 5 mins to put up take down.
The dealer will probably sell you a complete kit but at a cost.
From stock to big rock just enjoy what you got
Muddybrit is offline
post #3 of 12 Old 07-26-2009, 05:11 PM
Bishop Creek
A factory soft top should come with a built in header that latches just like your hard top does and you do need door surrounds.
The pictures below illustrate how the surrounds fit in the door frame and shows how the soft top fits into them. Also good for a tight seal with your doors. (First pic shows a bikini top on, but you get the idea).
ďThis isnít the Old West, because the New West has never arrived. Itís just the West, like Wyatt Earp died yesterday.Ē
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline
post #4 of 12 Old 07-27-2009, 04:23 AM
Neil F.
If yours was a hardtop only model, you will also need the bracket for the tailgate bar and brackets for the rollbar to attach the softtop.
Neil F. is offline
post #5 of 12 Old 07-27-2009, 08:31 AM
Bishop Creek
And make sure that you get LJ, Unlimited, door surrounds as they have a special pin on the top for the Sunrider feature that regular TJ surrounds don't have.
post #6 of 12 Old 07-27-2009, 09:48 AM
goofus
If you get a factory soft top kit, you will get EVERYTHING needed. That is your best bet and will be the best fit. I frequently see them on eBay for fair prices.
If piecing a factory top together:
Top itself plus windows
Door surrounds (and as mentioned the LJ ones have a pin for the Sunrider option- you could get away without if you don't plan on flipping up the front)
Hinge brackets (attach to cage- they're under the padding and just the tabs stick out)
Tailgate bar and retaining brackets (screw into tub just to the side of the tailgate on the top)
2013 2500HD
2005 Unlimited
2003 Rubicon
2000 SE
1997 XJ
85 FJ-60
goofus is offline
post #7 of 12 Old 07-27-2009, 11:45 AM
Neil F.
Unfortunatly not all sellers (ebay and others) always include everything (or know what to sell) but at least you will know what to ask about now.
Neil F. is offline
post #8 of 12 Old 05-13-2013, 04:50 PM
MintJulep
I am wanting to do the same thing on my 91. She is a Hard top only. Just not sure what I need to buy. Would love some advise.
MintJulep is offline
post #9 of 12 Old 05-13-2013, 05:01 PM
jeepn4life92
If you go with a top from bestop, it comes with the door surrounds as part of the kit and you need to purchase a drill in or removable header bar, but everything other than the header bar will come with what you buy, and its great quality, I have a repkacement style top from bestop and my brother has a trek top and both are top notch stuff, I also have a bikini top from them
jeepn4life92 is offline
post #10 of 12 Old 05-13-2013, 05:06 PM
RDaniel2405
Instagram @theorangejeep
RDaniel2405's Avatar
Click here >>> http://www.quadratec.com/advisor/jeep_soft_top/ Also, my opinion is the Bestop Supertop NX.
MY DAILY DRIVER BUILD
WTB Impact Orange half doors.
WTB Jeep JK Currie Front Track Bar CE-9120FJK.
RDaniel2405 is offline
post #11 of 12 Old 05-13-2013, 06:05 PM
smokeybear
Consider the Bestop Trektop. It comes complete. I just went from a hardtop to the Trektop. Much much quieter than the Bestop Supertop I had on the YJ. No framework to futz with.
02 TJ Sahara 4.0 5 spd, 3.73, Dana 44 rear, 2.5" lift w/ Bilstein shocks, 33x12.50
smokeybear is offline
post #12 of 12 Old 05-14-2013, 04:21 AM
Neil F.
Note this is the 97-06 TJ section. Your 91 YJ top is totally different from a TJ
Neil F. is offline
How Hard Is It To Convert 4cyl To 6cyl? yzman720 TJ Wrangler Technical Forum 10 07-04-2007 03:30 PM
Convert From Hard to soft top twomster YJ Wrangler Technical Forum 12 05-11-2005 08:52 AM
How hard is it to Convert 4cyl to 6or 8cyl Flendo TJ Wrangler Technical Forum 18 01-02-2005 07:32 PM
Wanting to convert over to a soft top JeepWranglerYJ YJ Wrangler Technical Forum 12 04-01-2004 06:10 PM
Convert from soft top to hard top RT8827 YJ Wrangler Technical Forum 11 12-10-2003 09:00 AM
