wandering steering and caster angle questions - Page 2 - JeepForum.com
post #16 of 63 Old 03-11-2014, 04:43 PM
Mike5087
No drop pitman. 2.5 Old Man Emu lift. JKS adj. TB. Everything else as far as steering goes is stock.
Was in the process of saving up for adj control arms as well as upgraded steering components and want get this little wobble under control.
"YES THE CAR MADE IT HOME WALTER, YOU'RE CALLING ME AT HOME!"
Mike5087 is offline
post #17 of 63 Old 03-11-2014, 06:26 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by Mike5087 View Post
Would you say caster plays a part in my tj sorta "wandering" I don't have DW. I have a slight shimmy that comes and goes every once and a while. My bigger issue is a floating feeling on the road.
caster could be a problem. have you had it aligned to see what the specs are? if so, post them up.
Here's a discussion on measuring caster. I run 6.5 caster with 33s on the OME lift, set using adjustable upper and lower control arms.
The JKS front track bar will hit the tie-rod or the diff cover, depending on the generation of bar, without 2" front bumpstop extensions. So that isn't helping your situation at all. You need to rectify that situation. Here's a summary on the clearance issues. Here's how I set up my front track bar at full bump with a V8 ZJ tie-rod and 1.375" front bumpstop extensions.
while we're on the subject, you also need to check the rear track bar clearances. I ran into some major issues back there as well, here's a summary on that. You may find reading through my build thread useful since I've already worked through these bugs....
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 63 Old 03-11-2014, 06:45 PM
Mike5087
Awesome. Will dive into those when I get some downtime at work. Appreciate the post!
Mike5087 is offline
post #19 of 63 Old 03-11-2014, 07:19 PM Thread Starter
motoxracer801
In my opinion that's the problem with mine. Then again I have factory control arms. Do you have aftermarket control arms? Adjustable or fixed?
motoxracer801 is offline
post #20 of 63 Old 03-11-2014, 08:05 PM
Mike5087
I have factory now. Next on my list was adj arms
Mike5087 is offline
post #21 of 63 Old 03-11-2014, 08:58 PM Thread Starter
motoxracer801
Mostly everyone I have seen that is complaining about wandering on the road has had our same setup. Which is "x" amount of lift with stock control arms. So I belive they have everything to do with our jeeps wandering.
post #22 of 63 Old 03-11-2014, 10:31 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by Shiftee View Post
Your caster is not likely to be the issue. I'm running 33x12.50's with a 4" lift, my camber is at 4.6
If your camber is 4.6, you've got some serious problems... IMO
Knuckelhead is offline
post #23 of 63 Old 03-12-2014, 04:38 AM
Shiftee
caster. Don't know how that got in there. I have zero problems anymore. Adjustable arms are on the to do list but it's driving fine for now.
Shiftee is offline
post #24 of 63 Old 03-12-2014, 06:22 AM
Unlimited04
caster does involve some personal preferences around drive-ability.... just because you like 4.6 caster, doesn't mean everyone else does.
I started at 4.5 and eventually moved to 6.5 caster in 0.5 increments, with 33s, and I very much prefer 6.5. 4.5 was scary by comparison. Jeep wandered all over lanes and followed every little defect in the road, plus return to center sucked...needed two hands on the wheel and a butt clinching the seat @ 65mph. With 6.5, I can hold one hand on the wheel @ 80mph.
Useful Write-Ups:
Funny:
post #25 of 63 Old 03-12-2014, 07:18 AM Thread Starter
motoxracer801
^^ agreed
post #26 of 63 Old 03-12-2014, 07:22 AM Thread Starter
motoxracer801
I've already had two seats re covered due to tearing them from excessive butt clinching in my jeep.. yeah... it's that scary to drive
post #27 of 63 Old 03-12-2014, 10:24 AM
Shiftee
I don't like my caster... I'm simply stating that I had massive steering issues before and explaining what I did to stop them. I don't have good return to center now, but I can hold one hand on the wheel at 80mph as well. Not recommending 4.6 caster to anyone. Simply stating that if the OP has issues other than his caster there are things he can do to improve his situation.
Shiftee is offline
post #28 of 63 Old 03-12-2014, 10:43 AM Thread Starter
motoxracer801
I don't believe I do have other issues than my caster. I self checked the Toe and it was correct according to my Internet finding. I've done a dry steer test and ball joints and bushings look good. I don't have a drop pitman arm. - (To my knowledge)
My brother in law who is a diesel mechanic has been dumb founded with it also. So with a little research I truly believe my culprit is my caster. How do I check my caster angle myself?
post #29 of 63 Old 03-12-2014, 10:47 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It is nearly impossible to get an accurate (!) caster angle on your own. Take it to an alignment shop for that particular angle measurement.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #30 of 63 Old 03-12-2014, 11:37 AM
robncar
robncar's Avatar
Oh c'mon Jerry... you can pick up a Hunter Alignment Quick Check Machine for about $21K
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
caster setting , death wobble , lift kit advice , wandering
