wagoneer d44 swap into LJ - Page 2 - JeepForum.com
post #16 of 70 Old 11-08-2009, 09:01 PM
russ03tjsport
Originally Posted by never monday View Post
I don't understand your sarcasm.
Add up all the brackets and an air locker for the Waggy. Oh, new wheels too.
but with the waggy front he would have a true dana 44 not a dana 30/44 crossbreed.
russ03tjsport is offline
post #17 of 70 Old 11-08-2009, 09:09 PM
never monday
So...you still have 297 u joints
never monday is offline
post #18 of 70 Old 11-08-2009, 09:51 PM
marcus01tj
dont listin to never monday... rubi 44s are a waste of money.. no hubs. unit bearings suck.. its basically a dana 30.they have weak axle tubes, and brackets. smaller tie rod ends.. the list goes on.
marcus01tj is offline
post #19 of 70 Old 11-08-2009, 09:59 PM
never monday
Lockouts explode, it takes more tools to replace a broken stub shaft.
Why don't you explain to Spidertrax about how unit bearings suck. Or how the 2 on the front axle of my Cummins lasted 185k.
Shall I go on?
post #20 of 70 Old 11-08-2009, 10:01 PM
marcus01tj
well when u see a rubi 44 with spider trax unit bearings show it to me and my dana 30 unit bearings didnt last 85k and they are the same as rubis
post #21 of 70 Old 11-08-2009, 10:05 PM
never monday
So just because you had a problem makes the axle ****?
That's as bad as the 35 hate
post #22 of 70 Old 11-08-2009, 10:09 PM
marcus01tj
well if u think a rubi 44s are so good. go buy some to replace your dana 35.:flipoff2:
well im done arguing in your thread man but i say build ya a waggy 44. ive got one and i built it my self for a whole heck of alot cheaper than a rubi 44
post #23 of 70 Old 11-08-2009, 10:14 PM
never monday
Down grade my S35 to a R44. No thanks.
Install a Waggy or R44 front? No thanks. I'll take a HP30 over either.
post #24 of 70 Old 11-08-2009, 10:17 PM
NEastUnlmtd
NEastUnlmtd is offline
post #25 of 70 Old 11-08-2009, 10:25 PM
marcus01tj
last thing... the ol turd polisher hahahaha :flipoff2:.. and it looks like he wants a real 44 instead of a rubi so lets get back to the tech.
as far as steering goes u can get a kit from ballistic fab with all your DOM, inserts, hiem or 1 ton ti rod ends, and jam nuts. and to change it from 6 to 5 you need to get chevy small bearing spindles and ford hubs and rotors( that is if u are keeping the waggy knuckles or chevy flattops) ive got ballistic fab xj/ tj coil buckets and lower ca mounts, then rubicon express upper mounts and truss. ive got a 4 inch lift on my tj and i had to go back to a stock pitman arm so i could get the correct geometry on my drag link and trac bar. hope this helps ya man
post #26 of 70 Old 11-09-2009, 06:30 AM
never monday
If the OP wants a "real 44" then he should ditch the Waggy idea. Then go find a 3/4 ton Ford HP44.
Swapping from a LP to an LP is a waste.
Marcus,
Leave your inbred childish comments somewhere else. They are not welcome on JF
post #27 of 70 Old 11-09-2009, 06:50 AM
cmoore
cmoore's Avatar
. Waggy's are not an upgrade and low pinions suck in general. All this talk of "real" 44 is a joke as far as I'm concerned. After you go through the waggy and shine it up (or any other 44 for that matter), you still have the same common failure point as the 30. Everybody cries "bigger ball joints" but how often do you see 30s blow balljoints (on 35s and smaller tires) ? I've seen more Waggy's break ball joints than I have 30s. Typical waggy failure: the ujoint goes, the driver stays in it a second too long and the balljoints go, then the wheel falls off. I've never seen that happen to a 30, have you?.
I've seen way too many friends build d44s, then realize that 44s aren't an upgrade, and build a 60. If you need durability beyond the hp30, go 9", 60, or bigger.
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline
post #28 of 70 Old 11-09-2009, 10:09 AM
marcus01tj
ive seen wheels fall off of hi pinion 30s too on 33s
post #29 of 70 Old 11-09-2009, 10:24 AM
never monday
And Tim Cameron broke the knuckle off of a 2.5ton Rockwell.
Anything can be broken. My point is why spend a thousand dollars for no gain.
post #30 of 70 Old 11-09-2009, 10:55 AM
marcus01tj
awesome dude.. you know a rubi 44 is low pinion too
Wagoneer Dana 44 swap gregg877 YJ Wrangler Technical Forum 11 10-18-2015 06:26 PM
89 Wagoneer swap CrSublime YJ Wrangler Technical Forum 4 01-18-2012 12:28 PM
Wagoneer D44 swap into my TJ 04<TJ>renegade TJ Wrangler Technical Forum 3 03-12-2008 05:01 PM
Wagoneer Drivetrain Swap xjh3 YJ Wrangler Technical Forum 2 07-08-2007 08:34 PM
Wagoneer D44 swap to Wrangler Lineleader TJ Wrangler Technical Forum 1 12-30-2006 11:09 PM
