Quantcast Waggy 44 into tj/yj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Waggy 44 into tj/yj
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 01-25-2009, 02:04 PM   #1
Solidkm
Waggy 44 into tj/yj
I am thinking about getting a waggy 44 front and putting in the front of my tj. I know that there is alot of info out there on this. I wanted to hear from guys that have done this or are running this set up. I am running 35s and really have no desire to go any better. i have no real problems with running a 30. but i want to lock it, and i would like the added strength of the bigger ring gear, and stronger tubes. I was considering going with a hp30 but i am thinking this might be better time and money spent. I know that the wheel pattern is different. i am not really worried about it. i read somewhere that someone said that waggy shafts are weaker the d30 shafts, is this true? any help would be great, thanks
Solidkm is offline   Reply With Quote
Old 01-25-2009, 03:04 PM   #2
Solidkm
or should i try and get a hp? what you guys think
Old 01-25-2009, 03:08 PM   #3
PBR
Ive herd good things about the waggy 44. My buddies doing that swap right now into his Tj running 35s
PBR is offline   Reply With Quote
Old 01-25-2009, 03:16 PM   #4
Solidkm
yaeh this looks like it might be the route to go
Old 01-25-2009, 04:05 PM   #5
rootin
I have a wagoneer front in my TJ, was not real hard to install but you will need to have some fabrication equipment to install all of the brackets
rootin is offline   Reply With Quote
Old 01-25-2009, 04:45 PM   #6
Solidkm
yaeh i am not worried about the bracketry, just basically wanting to know if its a good upgrade with out any real cons. other then the wheel pattern
Old 01-25-2009, 04:56 PM   #7
Solidkm
is this what i would buy if i wanted a shaft upgrade?
http://ruggedrocksoffroad.com/superior-dana-44-left-front-evolution-series-chromoly-axle-shaft-kit-30-spline-1980-1992-jeep-wagoneer-p-1614.html
Old 01-25-2009, 05:01 PM   #8
Greg_Volkman
Waggy shafts are not weaker than D 30 shafts. What are you running in the rear?
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Old 01-25-2009, 05:09 PM   #9
Solidkm
ford 8.8 31 spline version
Old 01-25-2009, 05:19 PM   #10
Greg_Volkman
you can get alloy 8.8 shafts with the same bolt pattern as the waggy. the HP axle crowd would probably poo-poo it, but i know plenty of guys that are doing it.
-0|||||||0-
Old 01-25-2009, 05:23 PM   #11
Solidkm
nice i like that idea. are they made by superior? they also make spacers to convert it. but the ones from adapt it would be 200. so might as well put that money towards the shafts.
so your saying it will be a good strength upgrade?
anyone know the tube thickness off hand? thanks
Old 01-25-2009, 05:28 PM   #12
UTWeezul
I've thought about going this route, but front and rear. I've got a friend with a Waggy that I could buy cheap because it is just sitting on his property in Virginia.
Enjoy life to the fullest each and every day!
http://www.midsouthjeeps.com/
UTWeezul is online now   Reply With Quote
Old 01-25-2009, 05:33 PM   #13
Chris98TJ
the 44 shafts and 30 shafts use the same ujoints
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline   Reply With Quote
Old 01-25-2009, 05:35 PM   #14
izanuff
This is false. Unless you are talking about a Rubi D44.
Originally Posted by Luckyduck View Post
I just went and grabbed 2 rubi axles locked and everything for $100 each then $1000 for 2 entirely new stronger housing and bingo I got 2 locked 44's that are as strong as 1 tons for $1200
1 TONS!
izanuff is offline   Reply With Quote
Old 01-25-2009, 05:41 PM   #15
Solidkm
dont mean to be helpless, but can you show me
Glock Forum
