vw diesel conversion kit for samurai, jeep? - JeepForum.com
post #1 of 31 Old 02-02-2008, 04:44 PM Thread Starter
zband
zband's Avatar
I was watching last week's extreme 4x4 and they had put in a vw diesel into a Samurai complements of a conversion kit, Does anyone know of similar conversions kits for the tj?
zband is offline
post #2 of 31 Old 02-02-2008, 04:48 PM
McLovin
No I dont.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #3 of 31 Old 02-02-2008, 05:50 PM
kd4yor
VW's engine offerings are to weak for a TJ
I don't have enough lift to "stuff a tire"
kd4yor is offline
post #4 of 31 Old 02-02-2008, 06:26 PM
chappy84
chappy84's Avatar
I don't think so. Anything can be made to work.
To the op I would go to extreme 4x4's web site (www.powerblocktv.com) I think.
Check out the company that made the conversion and call them, If they don't make it they might know who does. Low gears don't work well in diesel conversions because they do not allow the turbo to spool correctly so 3:73 with 35" tires works well but 4:56's will not allow power from the turbo.
I would also plane on loosing the rear seat to a fuel cell. (food for thought)
Let us know if you do this.
-CHAPPY-
chappy84 is offline
post #5 of 31 Old 02-02-2008, 06:31 PM
kd4yor
yes it could be made to work. BUT the VW 1.9 would be worse than a TJ 2.5 for lack of performance. Look at the KJ it has a 2.8 diesel. Most commonly the Cummins 4BT, either 3.3 or 3.9 are used in TJ diesel conversions. I'd like to use the KJ CRD if I could find one reasonably. The TJ in trail trim is about twice the weight of a Sammy.
kd4yor is offline
post #6 of 31 Old 02-02-2008, 06:40 PM
chappy84
chappy84's Avatar
I too would not use this motor but I wanted to point out that it would work i.e. twin turbos heavy injectors propane? Not exactly my Idea of making a worthwhile swap but it could work.
Anybody that is looking into making a step like this has or will weigh the pro's and the cons and will have to determine if they want to spend the dough for a VW diesel motor or a cummins???????
Good points.......Thanks.
-CHAPPY-
chappy84 is offline
post #7 of 31 Old 02-02-2008, 08:22 PM
Waldn
http://www.overlanddiesel.com/71/98.html
97 TJ SE 2.5L Auto, 3" BDS, 255/85-16 BFG MT KM
04 KJ LTD Frankenlifted, Full Mopar Armor, front reciever hitch for winch, Rubicon Moabs and MTRs
Waldn is offline
post #8 of 31 Old 02-02-2008, 08:42 PM
kd4yor
Originally Posted by Waldn
nice!!
I can see it doing well in the low ranges and reasonably well on the highway. What's the truck weigh? 3000?
kd4yor is offline
post #9 of 31 Old 02-02-2008, 08:46 PM
badoosh27
badoosh27's Avatar
i've been tossing around the idea of a diesel and looked at almost every option out there. in my opinion, with the weight of the TJ, i dont think anything under 3.0 liters would be worth while. like the guy above said, the cummins would be a better idea because it's got the brute strength that the 1.9 doesnt. like the old saying goes, theres no replacement for displacement...
this guy did the 3.9: http://web.mac.com/my96z28ss/iWeb/Jeep/Welcome.html
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #10 of 31 Old 02-02-2008, 09:48 PM
Waldn
Cummins 4BT in TJ
http://www.overlanddiesel.com/71/1534.html
Waldn is offline
post #11 of 31 Old 03-28-2008, 04:29 PM
xj#2
im confused
arent the vw engines.......for lack of the correct term transverse or set sideways because of front wheel drive? is it still possible to mate it up?
88 mj 4.0 5 speed 4x2
87 wagoneer 4.0 aw4 4x4
95 cherokee classic for parts 4x2
xj#2 is offline
post #12 of 31 Old 03-28-2008, 04:56 PM
fish4life
installing a VW engine in a TJ would be an utterly complete waste of time and money! What will you gain? Surely not HP, surely not MPG as you'll need to have that thing floored to go anywhere.
Now if you were to install the diesel out of a Liberty ... that's a whole nother story
fish4life is offline
post #13 of 31 Old 03-28-2008, 05:02 PM
BlueFlame
BlueFlame's Avatar
The "end" of the engine (one end of the crank) is still where it mates up, even in a transverse layout. There's many engines that are used in both, depending on the vehicle it's put in. Just need different axhaust setup and usually a different intake manifold.
Something like this:
BlueFlame is offline
post #14 of 31 Old 03-28-2008, 05:14 PM
never monday
To convert a VW engine gas or diesel to longitudinal from transverse. You'll need to make mounts. Depending on hood clearance everything else should fit.
never monday is offline
post #15 of 31 Old 03-28-2008, 05:22 PM
Lawrence
You obviously have never driven one of these... 310 horsepower, 553 lbs-ft torque, 0-60mph in about 6 sec, and still get over 20 mpg
Lawrence is offline
TJ 4.0 L Diesel Conversion superfunk TJ Wrangler Technical Forum 2 07-17-2007 11:05 AM
jEEP GIVE US THE DIESEL HECK IF THE hUMMER H3 HAD A SMALL DIESEL IT WOULD BE NUMBER 1 4.0v8eater JK Wrangler Technical Forum 22 08-02-2006 12:10 PM
Diesel Conversion Cheers YJ Wrangler Technical Forum 5 02-02-2006 06:01 PM
Diesel conversion austineo TJ Wrangler Technical Forum 10 11-08-2005 12:40 PM
Need more room Using a 50/50 split samurai seat in a Jeep? ncb76 TJ Wrangler Technical Forum 4 06-20-2004 10:15 PM
