VSS Location and Jet Accu Speed Installation - JeepForum.com
post #1 of 5 Old 09-17-2008, 07:40 PM Thread Starter
scanderw
Im in the middle of installing a Jet Accu Speed and am trying to locate the Vehicle Speed Sensor (VSS). I know it is located on the transfer case but want to make 100% sure that im not tapping into anything else. In need of pics/instructions of where the VSS is.
scanderw is offline
post #2 of 5 Old 09-17-2008, 07:45 PM Thread Starter
scanderw
VSS Location??????
VSS LOcation?????
scanderw is offline
post #3 of 5 Old 09-17-2008, 07:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
On the transfer case, it also holds the speedometer gear on non-Rubicons. It's on the driver's side and is held in by a single bolt, there is a cable for the speed sensor coming out of it.
Jerry Bransford is online now
post #4 of 5 Old 09-17-2008, 07:54 PM Thread Starter
scanderw
pics???????//?
scanderw is offline
post #5 of 5 Old 09-17-2008, 08:22 PM
RLD831
RLD831's Avatar
Pic taken from 4x4xplor.com
RLD831 is offline
Exactly which manual 5 speed Fill Plug Location? YJNot YJ Wrangler Technical Forum 23 06-01-2010 09:27 AM
Jet Accu Speed Control Unit Install Help flightmechs TJ Wrangler Technical Forum 0 10-31-2009 12:33 PM
3 speed auto breather tube location emahan01 TJ Wrangler Technical Forum 2 12-02-2008 10:31 PM
Wheel speed sensor location - axle replacement Grimscale JK Wrangler Technical Forum 0 10-08-2008 05:06 AM
Where is the factory installation location of the Sirius Module? solbergg TJ Wrangler Technical Forum 7 01-15-2007 09:25 AM
