#1 | |
Voltage Regulator Problems...I think...
Me again. One other problem with the '97 Sahara. Last night, the "check gauges: light came on, and I saw the voltmeter was buried on the top end at 19+ volts. Then, after a while, it would go back down to 14, where it should be. I figure it is the voltage regulator. Has anyone else had this problem? Is the voltage regulator in the alternator? Can the part be purchased and installed by a non-mechanic?
Thanks, ---Tim---
#2 |
Do it right or not at all
![]() Join Date: Jan 2003
The VR is located in the ECM (computer)... let's hope it's not that due to the cost of replacing it.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#3 | |
Get the battery checked first. Fred
[b]Base[/b] - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp) [b]Suspension[/b]- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar. HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56 [b]Misc[/b] - Tera 2wd lo. [b]Tires[/b] - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks. [b]Recovery[/b] - Warn XD9000i |
#5 |
Cleaned battery connectors
After cleaning and reseating all battery cable connections, the problem did not reappear. Thanks
---Tim--- |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
